Celeron 300A
Reply 20 of 28, by kreats
366 @ 550 was another popular option
Reply 21 of 28, by The Serpent Rider
Tried that. Didn't budged even with increased voltage. The magic of 300A comes from success rate - you can overclock it to 450 with crappiest CPU bin possible. Maybe you'll need to increase voltage a little bit, but it will work.
Reply 22 of 28, by rasz_pl
early 366 (January 1999) were awful, but got excellent somewhere in mid to late 1999. Looking at https://en.wikipedia.org/wiki/List_of_Intel_C … _based_Celerons maybe it was release of 466 in April that updated all lines to B0 stepping?
Reply 23 of 28, by The Serpent Rider
Yep, I have B0 SL35S. Still don't work on 550. Later revision is not a magic ticket, just better average overclock, if you compare it batch-to-batch.
Reply 24 of 28, by alvaro84
A few years ago I decided to get an overclocked 300A as it was super popular in its days and said to be easily and surely overclocked. So I wanted one that does the trick at stock voltage and run at 450MHz stably at default 2V. I don't know the reason but I have had quite bad success rate, like one in three to six in the scraps could do it, most of them were unstable in my P3B-F at those settings. What.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 25 of 28, by amadeus777999
I remember the 300A's from the "LAN days" - grouped with either an ASUS P2B or an Abit BH6 they would go from 450- to 504mhz delivering sweet Quake/II pleasure for 1/8th of the price of a PII-450. I remember sometimes "taping off" pins when using the ASUS board... maybe due to voltage manipulation...?
Reply 26 of 28, by smtkr
alvaro84 wrote on 2022-11-26, 00:15:
My SL32A won't do 450 at stock voltage. It gets all sorts of corruption. Increase to 2.05V will run most things, but it gets random crashing. It's been a fun toy to play with, but I was disappointed that it couldn't do 450 stock.
Reply 27 of 28, by Zeerex
kreats wrote on 2022-11-25, 08:53:
I’ve never forgotten the ZDTV (later TechTV, G4) screensavers series related to this one. I believe over the course of a few episodes, Leo was building a dual Celeron 366 with the intention to overclock each to 550Mhz. He would say it’s a PC that “goes to 11”.
Some googling, I found someone that posted the specs on Imgur of the build:
https://imgur.io/gallery/XUTvb
BP-6 Dual PII/III BX Socket 370 Celeron 366 PPG Dual, overciocked PC100 SDRAM 128 megs SB Live Value 3C905 XL 10/100 non-managed […]
overciocked
SB Live Value
3.5-inch Floppy
40x
WD29100 2 x 9.1 GB. UDMA66
ZIP 100MB USB
Orb 2.2GB
EDIT: another result from 1999, this build was said to have cost around $1500: https://m.slashdot.org/story/7712
Assembling a dual Celeron 1100MHz is a trivial project, suitable for hardware newbies. Leo LaPorte built one on ZDTV a few weeks ago for about $1500.
Reply 28 of 28, by acl
TrashPanda wrote on 2022-07-10, 11:00:
Quick question, is the Socket 370 version of the 300A the same chip that is in the Slo1 package ?
Am I right in thinking it was the 370 version that was the famous overclocker ?
I'm convinced that both are the same chips, just with a different interface.
I have a Slot1 version and removed the plastic casing a long time ago to add a better cooler.
Not much to see under the plastic. The only chip on the board is the CPU.
Front : https://retro.user-unfriendly.net/Parts ... front).jpg
Back : https://retro.user-unfriendly.net/Parts ... (back).jpg
I run mine at 450 on a Gigabyte GA-6VXE+ (Apollo Pro 133... I know, not a super great chipset)
As far as I remember, it's probably the piece of hardware I have for the longest time. It was the CPU of my first own computer in ~2000.
