First post, by infiniteclouds
I have a SB Pro 2.0, A=220, IRQ=7 DMA=1 as my jumpers and set blaster environment - which in testing is detected by Wolfenstein 3D. However, when I use the SS Setup/Installer and choose any of the following options get "Auto-Detect Failed".
  • "Old SoundBlaster Pro"
    "SoundBlaster Pro"
    "SoundBlaster 16"
    "SoundBlaster AWE32"
If I choose "Soundblaster" it hangs for a sec, throws no error and then gives me control again but choosing "Test digital card" gives the error "Test Complete. Digital Card NOT Detected". I get the same error if I manually configure The I/O, IRQ and DMA.
I can select Roland as my music card and it picks up and plays my SC-55 (which is plugged into an AWE64G that I'm using for MIDI only) no problem. The only thing I can think of is that when I edit the CYB.CFG file the "digi_drq" value remains at -1. What should this be set to? Digi_IO is correctly set to 544 (decimal for the hex 220), IRQ 7, card 3 (Soundblaster Pro) and dma 1.
How can I troubleshoot this?
Reply 1 of 8, by infiniteclouds
Okay, so I've figured this out. I forgot how much authentic retro gaming made a game out of just getting the damn thing working. I've revised the topic title to reflect the dual soundblaster +SC55 situation to further help anyone who looks up either topics - and also my future self when I inevitably forget 5 years from now
When trying to use the AWE64 Gold for Sound Effects/Digital Card while also using its Gameport for a midi synth like the SC-55 the game will freeze during the intro cutscene. Instead, I'm now using it for just Midi with its Midi I/O set to P300. I have the Gameport disabled on my SBPro2.0 but P330 still seems to have a conflict elsewhere.
System Shock's Install.Exe was throwing an error because while the SBPro2.0 was working in other programs there was a both an I/O and DMA conflict with the AWE64 Gold. CTCM could not run correctly either to initialize the 64gold either seemingly because of this.
Since this machine is a 98SE rebooted into MSDOS 7.1 I had to go into Windows Device Manager to reassign the 64G I/O to A240. Despite the fact that I already had the IRQ to 5 and DMA to 0 (low) and 7 (high) there was still a conflict on DMA1 appearing that preventing the SBPro 2.0 from being recognized. That was simply cleared by initializing the 64G with CTCM which fully pulled over its SET BLAST variables that I configured in the Windows Device Manager: A240 I5 D0 H7 P300 T6. From what I can tell that is all CTCM does, it does not give me the option to set what variables I want the AWE64G to use from within DOS itself. Regardless, that now freed up D1 (DMA) for SBPro2.0 and SS Installer can detect it. I now have SC-55 Midi through the AWE64G MPU and Digital Sound coming through the SBPro 2.0 - yay.
Only having one of these cards would have probably made things go a lot smoother (not sure if the AWE64G should be able to do MPU + Digital sound in SS without freezing during the intro) but I really do like having both Sound Blaster 16 and OPL3 in the same machine with no hanging note issues.
I'm sure now that I've shown that I'm not completely clueless but rather just 'ignorant' more people may chime in here. Feel free to do so! I am very much looking forward to my first ever playthrough of System Shock which I'll be doing blind. Huge fan of Thief & Arkhane Studios Dishonored and especially Prey (2017) so this should be a treat.
Reply 2 of 8, by smtkr
Glad you figured it out. I suspected it was a conflict, but I've never run two sound cards nor have I ever met anyone who ran two sound cards, so I didn't want to barge in on it.
I just played SS1 for the first time last weekend on my Orpheus. The sound in that game is amazing.
Reply 3 of 8, by infiniteclouds
I'm not familiar with Orpheus.
Interestingly, I've managed to get AWE32 Music option going w/AWE32 Digital Sound option. However, once I'm using the MPU401 on the AWE64 Gold the game will freeze on the intro if I try and use AWE32 digital sound. If I'm using the MPU401 on the 64G I have to use my SB Pro 2.0 for the digital sound. A bit of a shame because I actually can tell the difference in sound quality between the two.
Reply 4 of 8, by Joseph_Joestar
infiniteclouds wrote on 2022-11-26, 00:11:
AWE64 cards have a bug where using high sampling rates for digital sound together with the MPU-401 for connecting an external MIDI device results in stuttering. Contrary to popular belief, this affects more games than just Duke3D.
See here: Sound Blaster 16 Bugs and Deficiencies Summary
My retro builds
Reply 5 of 8, by Gmlb256
^ Yep, I have noticed a similar issue with Boppin' where the music isn't being played properly when using the SB16 or AWE for both digital playback and MPU-401 duties.
Interestingly, I haven't heard anyone having this problem with System Shock until now. To be fair, I only played the demo version.
Reply 6 of 8, by infiniteclouds
For System Shock it's not stuttering the game actually will hang altogether and digital playback will not work at all. I can use it for both FM/Digital or AWE Wavetable/Digital no problems.
Reply 7 of 8, by gerwin
Gmlb256 wrote on 2022-11-27, 22:15:
System Shock has the Miles audio drivers that most late DOS games used. So now it suggests all such games are affected in a similar way, but that is a bit hard to imagine...
Back then I noticed the SFX+MPU lagging the most in TIE Fighter, with its ambitious imuse music system.
Reply 8 of 8, by Joseph_Joestar
infiniteclouds wrote on 2022-11-28, 01:07:
This issue doesn't affect the on-board AWE synth. Only external MIDI devices which use the MPU-401 and daughterboards physically connected to the wavetable header (on other Creative cards which have that) are impacted.
gerwin wrote on 2022-11-28, 02:26:
Not all. Just the ones which use a sampling rate higher than 11 kHz for digital audio.
My retro builds
