Waveblaster Adaptor for IDE-HDD Swap Frames
Reply 20 of 26, by GrafWasili
Ulfenknulfen wrote on 2022-06-06, 13:10:
The first Edition of the Final Product is on Ebay (Germany).
Hey, are you still selling these? I might be interested 😀
Reply 22 of 26, by Marmes
I have one of these, It makes me very happy! You can't go better than this!
I made a machine with SB CT1600, SB16 Ct2770, Gravis Ultrasound Classic and PCMIDI connected to this wonderful drawer! I will take pictures later!
You should consider selling these.
Reply 23 of 26, by a_h_adl
While I like the first idea very much it made me thinking since we started to go this way, why not taking it a bit further and have a Multi-WaveBlaster expansion without the need of physically swap them? It can be electronically switched or even better, act as a mixer so you can test new combinations of different WaveBlaster sounds with different levels all together.
Reply 24 of 26, by Ulfenknulfen
Hi folks 😀
The project is completed with version 2.5 (Ernie Edition).
Thank you for your contributions and support! If you want to see the final version,
I recommend this video:
https://youtu.be/Hv4GitjTLgc?t=2941
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0, 2.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️🖱️USB HID Devices on PS/2 and Gameport.
Reply 25 of 26, by pc-sound-legacy
Hi Paddy, awesome project, and I appreciate the Ernie-edition that really helps me to conveniently swap wavetable modules and external midi modules for my recordings. Not just makes it easier, it also looks great and is well built. I should also mention the possibility to select the needed voltage and polarity for external modules. Thank you!
Reply 26 of 26, by Ulfenknulfen
pc-sound-legacy wrote on 2023-09-16, 14:46:
Hi Ernie!
It was a honor.
Here some more impressions:
best regards
Paddy
