Finally my first one is 100% done.
I just wanted to post all thing around the soldering that i have hade problems with if it could help any one in the future 😀
My plan was use pcb stencil with hotplate for all the small components, which in my world was suppose to be easier.
First board i did have problem that the bord was just keep restarting and did not find a real issue, so resoldered all the components again by hand instead and booted fine 😉
Second board was done by hand instead of hot plate, which i most say was way easier then expected.
Stupid problem i had with this one was that the board just hang on bios when sd card was inserted, that was due to a pin for the sbc wasn't soldered 100%
I also hade one problem where i did not get any mt32-pi sound, my first step was to remove the pc speaker and then try the output on  the GY-PCM5102 which also didnt output anything, as always at least for me i seem to get a non working PCM5102, doent matter if i buy the cheaper version also, so i would recommend put in the pc speaker after testing mt32-pi.
When having problems with usb mouse, i just gab a cheap non power usb hub that i had and connected the mouse to it, then the mouse worked without problems 😀
Otherwise the project is fun as hell,  but i do get it takes time to put one together 😀 my plan is to make 5 and probably sell 2 of them to cover my expense 😀
I will also make few clean sd images, dos 6.22/win3.1 , windows 95 and windows 98 just to be able to simple switch between OS.
* YES i do know the bigger screen looks silly, but i rather have a bigger one 😀
