PGA132 rotator boards
Reply 40 of 116, by feipoa
Sphere478 wrote on 2022-12-04, 06:29:
I’m routing in 6 layer for my attenpt.
Yes, two surface mount.
Unfortunately this means every pad will have two vias beside it. I can cover them with silk though.
As they say in mandarin, "jia you"!
This is 180 degrees with ground plane?
Reply 41 of 116, by snufkin
Can tented vias (solder resist over the top of the via) be used?
Reply 42 of 116, by Sphere478
90*
Not sure, how do I do a tented via in kicad? Or is it a option when ordering?
Sphere's PCB projects.
Reply 43 of 116, by maxtherabbit
Sphere478 wrote on 2022-12-04, 16:06:
90*
I believe you just go to its properties and change type to blind/buried. As long as the correct copper layers are selected it should do what you want
Reply 44 of 116, by Sphere478
Ah blind buried isn’t supported by jlcpcb
Reply 45 of 116, by maxtherabbit
Sphere478 wrote on 2022-12-04, 19:14:
You sure? I know for certain they don't let you bury them under copper layers - but if you set the type to blind/buried and choose the outtermost coppers as start and finish it should pass DRC
Alternatively you just manually edit the solder mask layer with a zone
Reply 46 of 116, by Sphere478
I believe vias don’t have any solder mask clearance. In other words the varnish should already be over them. Problem is that it isn’t always enough.
Reply 47 of 116, by feipoa
If it is going to be 6-layer, I'd suggest starting with 180 degrees.
I contacted JLCPCB a few weeks ago and they do not support blind vias.
Reply 48 of 116, by Sphere478
Already pretty far into 90* if I settle on a routing pattern for the outer ring the inner rings should fall into place
Reply 49 of 116, by Sphere478
Btw my current attempt is a pin tor pin woth no distinction for power and ground. Just a 90* twist of every single pin
Reply 50 of 116, by feipoa
I suppose if you create all 3 rotations before prototyping, it shouldn't be an issue. Due to the cost involvement with 6-layer, I would start testing with 180 degrees. Once it is determined that 180 degrees works, I won't be ordering the 90 degree and 270 degree units unless I run into an application which demands it, but I would keep the gerbers handy for the situation. The $85 cost is too high to order something before I need it, and right now I need 180 degrees. If 180 degrees works, then the other two orientations will likely work.
I gently alluded to this earlier,
feipoa wrote on 2022-11-04, 22:54:
For one such motherboard I have setup at present, the 180 degree orientation is the one it needs. However, I have run into this issue on a few motherboards.
Given the issue with possible VCC plane on the SXL2 interposer, I think a direct rotation of every pin might offer some further insight. I can even run the rotator board with the same SXL2-66 CPU using the Improve It + Gainbery and check for higher than expected noise.
Reply 51 of 116, by feipoa
If there's a way to force the 90 degree into 4-layer, then the situation is much better and we can experiment with the noise in greater depth for a fraction of the cost. But at 6-layer, to experiment, even with the 180 degree unit, one with no GND/Vcc plane, and another with all pins directly mapped, that will cost around $170 USD. If 90-degree cannot be 4-layer, then we should really start with 180 degree.
Reply 52 of 116, by Sphere478
So let me remind that this is a non offset attempt. Smd design.
I’m coming up one pin short 🤣.
I’m starting with the outer layer of course because it is the hardest. But it is making it pretty apparent that doing it in a organized way is kinda hard. Here is my latest routing pattern. I have managed to route all but one. I think perhaps if I shift half of each side toward center I can make another ring on the outside to route the corners.
    1.52 MiB
Reply 53 of 116, by Sphere478
Success!
Unfortunately this leaves a huge question mark for the middle ring. I don’t think there are is enough space left for middle with only two paths.
    1.9 MiB
Reply 54 of 116, by Sphere478
Sorry feiopa, I had already started with 90.
Kinda on a roll.
I’ll try to get to the others.
I’m trying to find a elegant way to do this, I don’t want it to be spaghetti. :p
Reply 55 of 116, by Sphere478
Outer and middle row routed. Middle should be easy now.
6 layer, ‘in place’, SMD, 90*
2 stacked bga style for 180*?
    1.78 MiB
Reply 56 of 116, by feipoa
I won't be available much until the kids are back in school.
You were able to do +90 degrees as 6-layer? Your latest PM suggested 8-layer was required.
Can 180 degrees be done 8-layer, SMD both sides?
Worse case, you could always start increase the size of the PCB, perhaps starting with 1 mm all around.
Reply 57 of 116, by Sphere478
feipoa wrote on 2022-12-28, 14:40:
I won't be available much until the kids are back in school. […]
Yes, I thought it wasn’t going to work, but I figured it out on pink layer. See the squiggly on pink?
Of course I could cheat and throw more vias everywhere, and make spaghetti but am trying to do it in a organized way.
This adapter is a clusterhump for signal interference btw.. The other approaches also, it looks like. So if it works at 80mhz that will be very interesting.
If we want to do something for that, we could go 10 or 12 layer and put ground planes between all layers. That would probably help. Then do bga stack for 180
It may be possible to route on less layers and fit ground planes between if we abandon the organized approach and throw more vias everywhere. But I still think that would be 8-10 layer at least and would look nasty 🤣
Idk, pros/cons.
But doing it this way (my way) it seems like 180 would take 12 layer at least. So the obvious solution is bga. This 90* is actually taking quite a bit of time to make. I’ve started over several times but seem to be on a roll with this latest one.
The nice thing is that the traces are almost equal length with this approach btw.
They get longer on the outside and shorter on the inside but the difference isn’t huge.
This is still 1:1 btw
If I went 10-12 layer how much would that be at jlcpcb these days? I know they changed their pricing recently. 🤔 if they can do it affordably adding ground layers might be a good idea.
Little redundant but I’ll also post the reply to the pm here as it kinda clarifies.
Rotator: Perhaps increase PCB size by 1 mm on all sides? Would that help meet 6-layer requirements? If not, and it needs to be 8-layer, that's just how it goes...
Increasing pcb size will only help if more vias are used you can only route so many before traces start to over lap. Jumping over a trace takes 1-2 vias depending. More vias means more length and less signal quality.
At this point I seem to have figured out the problem with routing middle layer. Inner layer should fall into place now and yeild a successful proof of concept for routing this way. The next step is ground plane. And the best way to ground this would probably require 4-6more layers. Because there is basically no chance of propagating ground on the signal layers
Reply 58 of 116, by Sphere478
I’m looking at the 132 pga pinout for a intel chip, and unless I am missing something there are no symmetrical vss/gnd locations.
So to ground the ground plane we have two options:
A spring in the middle to the metal lid on the back of the cpu
Or a external ground strap to a mobo screw.
(If we add more layers for ground)
Here is my current plan:
I’m going to silk the whole dang board. Cover all those vias, only holes will be the pads themselves
Then I’m gonna cut out the center and make it a hole, just because that’s how badass compact I’ve made this 🤣.
And finally, unless apposed I’m going to add ground layers and make the pcb edge conductive so that a ground strap can be soldered to it. Or/and may put a suspended spring holder in the middle. Will see.
Reply 59 of 116, by Sphere478
Fully routed.
I gotta go back and make sure all the pins are rotating the same direction (easy fix so long as I catch it 🤣)
Then a few passes checking the trace routing for clearance/optimal paths. Also need to add ground layers. I think it would probably be a mistake not to have them.
    1.65 MiB
