Reply 620 of 1383, by Sphere478
Doesn’t seem like much point in making that yellow cut as the motherboard and cpu internally will bridge across it
Sphere's PCB projects.
Reply 621 of 1383, by feipoa
rasz_pl,
LP is a short abbreviation I'm using to distinguish between the two types of VRMs that I have and will work on this interposer. The LP38503TSX-ADJ is the currently installed VRM on the interposer.
The attachment LP38503TSX-ADJ_setup.JPG is no longer available
Reply 622 of 1383, by feipoa
Due to the difficulty in constantly removing/resoldering the VRM, I'm doing these tests with my benchtop variable DC supply w/new cable. We can see the scope voltage reading and the supply reading are now in agreement.
The attachment New_benchtop_setup_1.JPG is no longer available
The attachment New_benchtop_setup_2.JPG is no longer available
The attachment New_benchtop_setup_3.JPG is no longer available
Here is the baseline for noise. On this motherboard, it is at 2.5 KHz rather than 800 Hz. The noise is still at 200 mV, with variances between 184 mV and 216 mV.
The attachment New_benchtop_setup_4_noise.JPG is no longer available
I remove the memory and turned the system on, but the noise is still present:
The attachment New_benchtop_setup_REMOVE_RAM_still_noise.JPG is no longer available
I did document some current measurements at 80 MHz,
3.6 V = 467 mA
3.8 V = 496 mA
4.0 V = 541 mA ---> becomes 600 mA at full load (DOOM)
4.2 V = 568 mA
4.4 V = 602 mA
4.6 V = 638 mA
4.7 V = 655 mA
4.8 V = 675 mA
4.9 V = 688 mA
5.0 V = 707 mA
At 40 MHz,
4.0 V = 374 mA
1 A seems like a realistic maximum, assuming 5.0 V at 100 MHz w/peltier.
Reply 623 of 1383, by feipoa
I figured out why the system was hanging with trying to clock-double on this motherboard. I was relying on the BIOS to setup the SXL parameters. I thought it had them correct, but I guess not, so I'm running them in software. I suspect caching of the adaptor ROM region was hanging the system. But here we can see after a hang-up, the noise and current draw drop.
The attachment New_benchtop_setup_HANG_on_clock_double_because_caching_ROM_region.JPG is no longer available
At 250 us (same as other scope images for low-freq):
The attachment New_benchtop_setup_HANG_on_clock_double_because_caching_ROM_region_250us.JPG is no longer available
And zoomed out to 50 ms:
The attachment New_benchtop_setup_HANG_on_clock_double_because_caching_ROM_region_50ms.JPG is no longer available
And here we see the current drops to almost nil:
The attachment New_benchtop_setup_HANG_on_clock_double_because_caching_ROM_region_HANG_low_current.JPG is no longer available
I'll get to work on adding those 100 nF ceramic caps to PGA pins.
Reply 624 of 1383, by rasz_pl
"System halted" screen finally made me realize bios is turning off interrupts and issuing HLT instruction = CPU is stopped.
New_benchtop_setup_REMOVE_RAM_still_noise.JPG interesting, 2.5KHz still there, but high feq element is gone. CPU spinning executing loop from internal cache?
Would love to know where 2.5KHz (and 800Hz on another board) is coming from. Can you put another scope probe on HOLD/HLDA to see if there is any activity at all (and correlation)? Would stopping CPU for a brief moment produce such drastic ripple?
>The low frequency noise of 700 Hz varies somewhat depending on what crystal oscillator brand or speed is installed. I've seen 700 Hz, 800 Hz, or 1500 Hz.
could this really be harmonic from main oscillator? put another probe on CLK2 pin too see if thee is any correlation, but how?
all of the questions and no answers 😀
Reply 625 of 1383, by feipoa
While I too would like to know the answer to the questions, their relevance will soon subside...
Reply 626 of 1383, by feipoa
Yes, I've seen oscillations at 700 Hz, 800 Hz, 1.5 KHz, and 2.5 KHz. I have dozens of different oscillators but I only tested a few. One yet another oscillator, there was no waveform but just noise over that 200 mV span.
I have placed ten 100 nF 0805 capacitors in the configuration shown. I wasn't soldering for beauty here.
The attachment 01_Ten_100nF_Caps_on_PGA_processor.JPG is no longer available
The attachment 02_PGA_SMD_100nF_0805_cap_placement.JPG is no longer available
Here is the setup:
The attachment 03_Ten_100nF_Caps_on_PGA_SETUP.JPG is no longer available
The oscillations disappeared and the noise is at 80 mV:
The attachment 04_Ten_100nF_Caps_on_PGA_LOW_freq_40MHz_AT_on_1x.JPG is no longer available
If I clock double, the noise reduces to around 64 mV:
The attachment 05_Ten_100nF_Caps_on_PGA_LOW_freq_80MHz_AT_on_2x.JPG is no longer available
This is a good deal improvement over the 200 mV (1x) and 160 mV (2x) noise witnessed without these 10 caps.
Reply 627 of 1383, by feipoa
If I leave the variable DC supply on, but turn off the motherboard, the noise is at around 16 mV:
The attachment 06_Ten_100nF_Caps_on_PGA_LOW_freq_40MHz_AT_off.JPG is no longer available
An image showing the current used by the SXL2 at 80 MHz:
The attachment 07_Ten_100nF_Caps_on_PGA_600mA_at_80MHz.JPG is no longer available
At this point, I'm wondering to myself: The motherboard only has two caps around the PGA132, so what kind of noise would we see if we install a regular ceramic SXL-40 PGA-132? The setup:
The attachment 08_Ordinary_PGA132_SXL_SETUP_1.JPG is no longer available
The attachment 09_Ordinary_PGA132_SXL_2.JPG is no longer available
The noise was at 168 mV, but not really a waveform:
The attachment 10_Ordinary_PGA132_SXL_LOW_and_HIGH_freq_noise.JPG is no longer available
So perhaps the SXL2 interposer board is in resonance with whatever minor low frequency oscillation there is, thus amplifying it? Nonetheless, with an ordinary SXL showing 168 mV of noise, the SXL2 interposer without those ten 100 nF caps is probably within some tolerance. Obviously, I will be leaving the ten caps on my board. Their proximity to the PGA pins seems important since adding ceramic caps to the centre region did not help with the noise issue.
Next up, I will be removing all the centre caps and check for increased noise, if any, and optimise these values. Then will be adding the MIC branded VRM back onto the board, check noise, then swapping it for the LP branded VRM to compare the two VRMs. I will then assemble a second unit and try to determine if 10 caps are really necessary and if we can get away with just 4 PGA caps. Once this is determined, I bet we could add some 0603 sized solder pads next to these PGA pins. However, this may not be necessary
Reply 628 of 1383, by feipoa
However, this may not be necessary because if you haven't soldered the PGA on yet, you can fit an 0805 tightly between the pins, like so:
The attachment IMG_1100.JPG is no longer available
0603 is a bit harder to solder.
Reply 629 of 1383, by maxtherabbit
feipoa wrote on 2022-12-05, 14:09:
that's actually fairly elegant, I like it
Reply 630 of 1383, by Sphere478
Sheesh, all I gotta do is add some silk there to indicate the cap. If those tiny caps between pins is all that is needed wonderful!
We are basically making a ppga pentium mmx 🤣
If you determine that the center region isn’t needed I can replace it with ground flood which will improve signal integrity
I can also try a different approach to how the center is configured
Reply 631 of 1383, by pentiumspeed
That is correct way to deal with! I said MLCC capacitors all along, But why is the 8 capacitors not populated in the center area, preferably large MLCC capacitors?
In newer designs and in all of the consoles including xbox one, and X and xbox series, PS4 and PS5 uses heavy use of large MLCC capacitors over 20 to 30 of them and about 8 to 10 tantalums.
And the input 12v on the motherboard is not many polymer capacitors, around 5 or so total.
Cheers,
Great Northern aka Canada.
Reply 632 of 1383, by rasz_pl
feipoa wrote on 2022-12-05, 14:08:
interesting, one thing to remember is here you are measuring whole motherboard noise, not just the cpu like on the interposer where Vcc3 is isolated.
Which gives me another idea - next time you will be measuring with interposer put second probe on 5V to compare. EDIT: wait, I think you did that before and 5V was clean?
the fact it worked before was a testament to that
as I kept repeating 😀 cant just plop caps anywhere, speaking of which:
Yes, they are on the other side of the circuit from LDO, they might be doing very little
ignore those footprints in the middle, if you want to add bulk caps solder them on top of Cout
I would feel a lot more comfortable if 5V fill was shrank away around those caps
pentiumspeed wrote on 2022-12-05, 18:59:
I remember you saying lowesr 😜
All of those are powered by buck converters, where caps are essential to smooth power output. Here we have perfectly smooth output, and need to decouple the chip to smooth load spikes. Not to mention 5W versus >100W.
Reply 633 of 1383, by pentiumspeed
I didn't say lower. I meant lower ESR is better. MLCC capacitors have this and can output higher current spikes which is what you did. Tantalums is good for bulk capacitance but needs so many to get desired lower ESR goal which is counter productive. Instead, use fewer tantalums and much more in number of large ceramic MLCC capacitors, around 1uF to 10uF. I ordered a batch of 2.2uF and 22uF MLCC capacitors for my repair and improvement projects on GPU cards.
And when I said distributed capacitors on each power plane helps with lower that ESR due to parallelism will handle the high frequency noise and spikes better.
Ground and power planes needs to be strong and thicker, more vias to help with current demands. Like 2 vias or 4 vias per pad and many vias if you need to transition from top to any layers.
Cheers,
Reply 634 of 1383, by Sphere478
Okay, if we can indeed put caps there, this will for sure be better I mean, we honestly can’t get a better placement than that.
Okay I am preparing the pi.0 version If I am understanding correctly the caps in this location solve the oscillations on the power plane.
I will wait for a full parts list and a list of cpu models. I understand there are more than one model of this cpu?
I wish to include all relevant infos on the silk screen. But will wait for Feipoa to finish tests. Here is a preview of the pi.0
As you can see in gerber view silk isn’t covering pad in final CAD files
Reply 636 of 1383, by Sphere478
I added silk around the locations because of the fill proximity issue. These are in an area where fill is at a premium.
I was going to square off the pads to make the caps look nice but that led to less fill cross section and other issues so I went back to round pads
Feiopa,
Is there enough room for four caps near the regulator? It’ll be tough but I may be able to move them toward socket and add two more pads
Btw, these caps for the pins, non polarized right?
Reply 637 of 1383, by pentiumspeed
I can see the problem. Not enough vias for power plane and ground. I'm talking about isolated vias not other than for pins as vias (not enough current handling), and relying on power plane for rest.
The examples of vias next to pads for capacitors:
http://www.sigcon.com/Pubs/news/6_09.htm
The ideal design is several vias to connect to inner layers for power planes around the regulator's pins, capacitor pads with 1 or 2 vias each. May have to enlarge the PCB little more by 30%, to make room for vias. Regulator needs lots of vias to connect to rest of power planes, and two tantalums gets their vias too. Are you now on 4 layers, may consider go 6 layers.
The practice is inner layers get power and ground, next is buried tracks going other ways and around the power and ground vias and then top and bottom mixed of power planes and ground planes and tracks. But you need to bridge the power planes to make connections at one end to another.
Spikes that look tall and thin can be instantaneous in order of around 20A to 50A in nanoseconds even for this little CPU of yours during CPU loaded heavily. With higher power CPU and GPU the instantaneous current goes up so much like 200A or more in nanoseconds.
This is typical design of APU with this capacitors and many vias look like, I know this is extreme.
https://guide-images.cdn.ifixit.com/igi/S5Uno … 5g5uVSO6HM.huge
https://guide-images.cdn.ifixit.com/igi/QiyYG … B2mVAtCcxy.huge
Cheers,
Reply 639 of 1383, by pentiumspeed
https://www.researchgate.net/figure/Compariso … ts_fig4_3364576
https://electronics.stackexchange.com/questio … r-traces-and-gr
https://www.intel.sg/content/www/xa/en/suppor … /000084801.html
This is power and ground via connections to connect to the planes from vias style do you have this in your PCB design software? This is cross style.
https://www.altium.com/documentation/altium-d … tyle?version=21
Cheers,
