First post, by AvocadoLongfall
I was curious if it would be viable to swap out my all isa riser board on a Zenith Data systems Z Select 100XE with another riser board that can go in that has also some pci slots?
I was thinking in theory that my i486 computer may apprewr to have pci slots on the motherboard that the riser card utilizes, I may technically be able to use another riser card with isa and pci or vlb and swap out the all isa card out should I want to make it so.
Reply 1 of 6, by Horun
You would need a compatible slot riser, many of the slot risers that have PCI go into a ISA/EISA looking slot that the ISA part is also routed too.
I do not think your board could even use a generic ISA type riser as it appears very proprietary with the ISA part not looking like an ISA slot, and with ISA and PCI separated....
Reply 2 of 6, by AvocadoLongfall
Yeah. Was told that I could only use whatever riser card I have so I can only use isa cards and stick with DOS games.
Reply 3 of 6, by Windows9566
that board looks exactly like the Packard Bell PB450
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 4 of 6, by BitWrangler
Might be, zenith and PB had a fling in the 90s.
Reply 5 of 6, by AlessandroB
I explored the world of swap riserboard but in IBM models. From what I know (but I could be wrong) only IBMs have this system and it's called "Selectabus". In the 486s that support it (like my PC 330DX4) I can install two types of spares the first is ISA+VLB and the second is ISA+PCI. But while ISA+VLB seems to be passive (i.e. brings contacts from the mainboard back to the slots) ISA+PCI has a chip on the riserboard which I guess is a bridge chip between VLB and PCI because I think the chipset on the MB doesn't natively support PCI . unfortunately they are super rare and I have never been able to find one and the documentation is not easily found either.
