Reply 600 of 1049, by 43purism
Hello guys, my first message here. Thanks for the author and everyone involved in this awesome project. I can’t wait to build my weeCee too.
First I have to say that the weeCee ticks many of the boxes of what I see as the perfect retro gaming board. I understand that this forum is mainly about reliving the authentic feeling with old games but I am interested in new ways of enjoying old games using modern technology too. I have been lurking here on this forum for quite some time now and as far as I can see, I’m in the minority of people wanting to get pixel perfect images from DOS machines. Of course I can get a cheap monitor with VGA input or a solution like OSSC that converts VGA signal to HDMI or DP but none of these options are satisfactory in my opinion. Monitors with VGA input nowadays are old technology, often the picture quality is not pleasant to the eye and almost always is the viewing angle inferior compared to monitors with an IPS or VA panel for example. Besides, getting a VGA monitor solely for playing DOS games is a bit unnecessary if you already have a modern monitor that’s miles ahead in terms of picture quality and whatnot.
Converter solutions are not perfect either. In none of the examples I have seen was the signal converted perfectly to digital and looked undistinguishable from the original, even with the most sophisticated and expensive gear. There is always distortion, warping, blurring etc. involved when converting an analog signal to digital signal.
So I’m exploring ways of getting digital image out of the weeCee. The datasheet of SOM304RD-52VINE1 mentions that the module outputs a digital signal (DVO) meant for LCD displays. You can use a (proprietary?) 44-pin box header connector to connect an LCD screen. This signal can be converted to LVDS using a converter ICOP sells on their website. I was wondering if that LVDS signal could in turn be converted to HDMI or DP for getting a pixel-perfect image. That way you would have the best of both worlds: retro computing on authentic hardware + the advantages emulators like DOSBox have regarding pixel-perfect picture quality.
