First post, by haker120
What file to use to update? I have version from attachment.
Reply 1 of 6, by PARKE
ooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
note:
LM 75/78 describes the Hardware Monitoring feature
If the right pane with the fan speed, temperature and voltage control appear
in the power management on the bios setup, so you have the LM75/78 hardware
monitoring feature and should update with the appropriate bios.
If not, you don't have the feature.
ASUS removed it from some new boards to reduce costs.
Reply 3 of 6, by Gmlb256
ASUS still has these BIOSes (click "Show All" to see the rest) on their website. It also has the Aflash BIOS tool.
Reply 6 of 6, by _tk
In case anyone else has this question...if you look at the pdf manual that asus still has up for this board on their website, they point out where the chip is/would be on the motherboard (for the monitoring feature).
Then flash the bios accordingly. Everything is still on the asus website (which is awesome and much appreciated).
