First post, by gekko
Hello, i use Dosbox only for old school programming languages like Turbp Pascal and so. Now my question, can i change the Shortcuts like Ctrl-F9(for Close dosbox!) is in TurboP. "Run". Then i will run my Programm close dosox, i will not work with the Mouse. Thx.
gekko.
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
See the readme about how to start and use the mapper.
[moved]
Reply 2 of 4, by MiniMax
Rank Moderator
Moderator
I don't think you can change that DOSBox uses CTRL-F9 for terminating itself. But as wd says, you can use the keyboard mapper to find another key to use as the Turbo Pascal "Run" key.
_________________
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
The ctrl-f9 is present in the mapper (shutdown) so i assume it works.
Reply 4 of 4, by gekko
OK, thx. Closed.
