First post, by _StIwY_
Hello i just got a Sound Blaster AWE 32 CT2670 but remains unrecognizable under BIOS and Windows 98 while another old SB 16 ISA is perfectly recognized. Do i have to assume the card is broken or maybe there is a conflict with the motherboard ( an Asus P3B-F with latest BIOS upgraded). Or maybe since it is not PnP do i have ti configure it manually ?
There are some jumpers at the audio card but i do not want to touch anything unless i know what i'm doing. Any tip is appreciated.
Thanks.
Reply 1 of 6, by Boohyaka
Good job, it's arguably one of the best AWE32 model. It is not Plug and Play, so it's normal you don't see it in the PnP devices when booting, or that it is not automatically detected by Win98.
Being non-PnP, it is actually configured by jumpers. You will find an explanation for them there.
In Win98, you will have to manually add the card via add new hardware. It hopefully should come up during the second phase (non-PnP device detection) of the wizard, if there's no conflict.
Hopefully this gets you started - good luck 😀
Reply 2 of 6, by Gmlb256
IRQ, DMA and HDMA are software configurable, I suggest leaving them to the default values for now which are 5, 1 and 5 respectively.
In DOS it must be initialized with DIAGNOSE /S after the BLASTER environment variable is set.
Reply 3 of 6, by _StIwY_
All right so i shoot some pictures, i don't get how modify the jumpers......it's a mess to me
Also i can't calculate how much RAM the card have onboard
https://postimg.cc/gallery/5JC704F
Reply 4 of 6, by kixs
Search for program UNISOUND here on Vogons and run it. It will configure the card to use in games. It will also show how much memory it has - 2, 8, 28MB is possible via 2x SIMMs.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 5 of 6, by snufkin
I think those are 1MB SIMMs, so 2MB in total. Based on datasheet here: download/file.php?id=152414&mode=view saying the chips are 1M address * 4bit, so 0.5MB on each chip.
Reply 6 of 6, by _StIwY_
Thanks a lot, i got this
