First post, by Paul_V
- Member
Hi all.
Recently, I've been given a broken Intel Advanced/ML (Marl) motherboard.
The motherboard itself checks fine, but its has some damage where the BIOS chip should have been placed.
N28F001 is a nasty chip with protected area and I guess this damage was a result of an unsuccessful attempt to desolder it.
I can repair the traces with no big trouble, I even have some spare trace&pad kits to glue and fix (used in smartphone repairs).
What really bothers me is how to solder an IC socket in a way that it would not rip off any more traces when the chip is pulled off.
I would appreciate some ideas, if anyone have experience with it.
So far I considered these options:
1) Fix IC socket in place with a dot of epoxy (a bad solution it terms of future repairs, may also rip off\corrode a chunk of the pcb)
2) Solder the chip as-is (Good enough to repair, but I would like to tinker with MR-BIOS and be able to take the chip out in case something goes wrong)
3) Find and solder TSOP chip instead (but these are rare and have even more rare expensive socket)
