First post, by Jackhead
- Oldbie
i use a UDMA Adapter on my IDE bus for running a Msata 32GB solution.
My Bios (Asus P5A) show the size correctly (i think it can up to 128GB).
Now i want to create some partitions for my pure DOS6.22 system.
So here my questions.
I know max partiton size with fdisk (DOS6.22) i can create 2GB.
But i can only create 1 primary DOS and 2 expanded 2GB partitions?
Or can i do more with another programms?
I run old ISA boards like a SB AWE 3980 where i read that i can getting problems with drivers on DOS 7.1+ ?
So im not sure if i should go up to a fat32 DOS. Not a solution if my drivers dont work and i get mem problems with old games.
I never used another dos as 6.22 .
Any suggestions?
regards
Chris
