First post, by Shponglefan
I recently acquired a Cumulus Corporation 286-to-386 upgrade board. It uses a 386SX-16MHz processor. It has a socket for a 387 co-processor as well, though that is currently unpopulated.
I installed it in my Epson Equity III+ and it is showing up as a 386SX processor, though running at only 12 MHz. I'm assuming there may need to be some driver/TSR to possibly configure it to run at the stated 16 MHz. (Note, the stock system speed is 12 MHz).
Anyone know anything about this board? The board itself is marked with "SX2LC" yet searching for that pulls up no results, and I haven't found anything else about this board online.
Even the seller's listing only stated it was pulled from a working system, but didn't really provide any details beyond that.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 11, by Shponglefan
Did some more searching on archive.org and found a reference to this board in a book called "Upgrading PCs Made Easy" published in 1991.
Also found a magazine review that makes reference to setting a jumper wire and needing a driver configured via CONFIG.SYS. Unfortunately, cannot find the actual drivers or manual for this thing anywhere. 😒
Reply 2 of 11, by Disruptor
What speed was the computer before, when the 286 had been in the socket?
Reply 3 of 11, by Shponglefan
Disruptor wrote on 2022-12-26, 18:41:
12 MHz
I also just tried lowering the system speed to 6 MHZ via the speed selector switch, and SysInfo then reports 6 MHz.
So it is tied to system clock speed. I just wonder if there is a way of enabling some sort of multiplier to boost the processor speed of the 386.
Reply 4 of 11, by Disruptor
Yes, and according to the manual it runs the ISA bus with 12 MHz (page 9, of https://files.support.epson.com/pdf/e3p___/e3p___pg.pdf )
Third Party Option Boards
If you find that some third party option boards do not function properly in the Equity Ill+ at the higher speed, try setting the CPU speed back to 6 MHz or 8 MHz.
When installing a memory expansion option board, make sure that it is a board capable of supporting the higher bus speed (10 MHz or 12 MHz) of the Equity Ill+. Some boards are rated for no higher than 8 MHz.
This section is also interesting:
Software Problems
When installing a copy- protected software package on the Equity Ill+, set the the CPU speed to 8 MHz. This has been found to have fewer conflicts with copy-protection. After the installation, the CPU can be switched back to the higher speed.
If a software package does not appear to be compatible with the Equity Ill+, try switching the CPU speed to 6 MHz and/or 8 MHz before giving up. Some software packages (e.g., Microsoft Chart 1.01 and Think Tank 1.001) have been found to function only at 6 MHz and 8 MHz
Reply 5 of 11, by Shponglefan
Disruptor wrote on 2022-12-26, 18:50:
Yes, and according to the manual it runs the ISA bus with 12 MHz (page 9, of https://files.support.epson.com/pdf/e3p___/e3p___pg […]
This is referring to ISA expansion cards though.
In this case, I'm trying to use a processor upgrade. Thus I'm wondering if I need the original DOS drivers for this particular Cumulus 386SX to potentially enable some sort of multiplier to enable higher clock speed.
Unfortunately, I can't find either original drivers nor the manual anywhere online.
Reply 6 of 11, by Shponglefan
Found another magazine blurb about this upgrade. This one is a bit confusing as it says it replaces 286 processors up to 16 MHz. So that does that mean the processor speed of the upgrade is directly tied to the system clock speed (e.g. no multiplier)?
Reply 7 of 11, by Disruptor
The 386SX on the board is specified to run with up to 16 MHz.
But your 286 motherboard is not.
It runs with up to 12 MHz, but it is overclocking the ISA bus as I have quoted.
It is fine on a 286/16 that runs the ISA bus with 8 MHz using a 1:2 divider.
And I don't give anything up to the "performance gain of 10 percent to 15 percent". It's just a marketing gag.
But, however, you can run software that uses the 386 protected mode.
Perhaps the included driver is nothing else than an expanded memory manager like EMM386.SYS / EMM386.EXE.
With your 2 MB of XMS you may run Windows 3.0 / 3.1 / 3.11 in enhanced mode: WIN /3
real mode (just in Windows 3.0): WIN /R
standard mode: WIN /S
Reply 8 of 11, by Shponglefan
Disruptor wrote on 2022-12-27, 00:22:
I suppose if this particular 386 upgrade board doesn't allow for a speed multiplier for the CPU, my next step would be overclocking the MB itself with a faster crystal.
I have a spare MB for this particular computer I was thinking of using for overclocking experimentation anyway.
Yeah, the other review I posted suggested this particular upgrade board doesn't really make things any faster. Though I suppose I could benchmark the original CPU and this board and see if there is any appreciable difference.
Reply 9 of 11, by Disruptor
As your motherboard does not divide FSB clock to ISA bus I absolutely do not recommend you to upgrade the board with a faster crystal.
You may damage components and do experience instability.
Reply 10 of 11, by Shponglefan
Disruptor wrote on 2022-12-27, 00:54:
Correct, that is a risk I am aware of.
This is why I have a second set of hardware (motherboard and RAM/ROM board) for this particular system.
Reply 11 of 11, by rmay635703
Change the crystal for
14.31mhz operation (28.62)
15mhz
Then 16.66mhz and see if it works
Hopefully your ram is 80ns or faster
Good Luck
