First post, by MiniMax
- Moderator
Seems like I have a weird bug on my system. Whenever I exit Windows Media Player it will turn the volume of my MIDI/Synthesizer device (in the sound volume control panel) down to zero.
When I then open an MIDI file with any of my media players (wmplayer.exe, mplayer2.exe or realplay.exe) the player will automatically adjust the Synth volume so I can hear the MIDI file. It looks like each player adjusts the volume to match its local volume slider.
But DOSBox will not adjust/raise the volume, so all I get from DOSBox is silence until I manually raises the volume.
dxdiag.exe has the same problem if I choose the emulated Microsoft MIDI Mapper or the Microsoft GS Wavetable SW Synth devices.
Could you guys try to open your volume control panel and see if your players messes around with the volume settings, and if DOSBox is - or is not - adjusting the MIDI volume on your PC's?
_________________
