First post, by Shponglefan
Not sure if this has been posted here before, I but I stumbled across this restoration of an Atari 800 XL that is on another level.
The originally damaged Atari looked it had been crushed, with huge portions of the plastic case missing, bent metal, corrosion, missing parts, and more. The restored unit looks nothing short of remarkable.
The author does opine that they "could have done way better", but it's still amazing considering how epically damaged the original unit was.
It's inspiring to see what level of restoration is possible with these older machines.
https://retrohax.net/extreme-refurbishing-epi … 00-xl-part-one/
https://retrohax.net/extreme-refurbishing-epi … 00-xl-part-two/
    309.42 KiB
    268.01 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 5, by Horun
That is impressive ! Thanks !
Reply 2 of 5, by Deunan
I was already impressed with the level of attention that PCB got (getting it straight is one thing, but injecting the cracks with epoxy resin is quite new to me). And then I saw he didn't just swap the case but actually filled the gaps... I'm in awe. I doubt I could do that, I never got those plastic airplane models quite right no matter how hard I tried 😀
Reply 3 of 5, by Shponglefan
Deunan wrote on 2023-01-05, 12:42:
That's what really impressed me about it. That they didn't just swap the case, but fully restored it using metal rods as rebar, silicone molds and poured resin.
Reply 4 of 5, by gerry
i was impressed how the board got working without replacing nearly everything, meaning much of it was essentially functioning just awaiting these careful steps and a few choice replacements to restore to life
Reply 5 of 5, by Gmlb256
Very awesome and detailed way to restore hardware! It would be incredible for preservation!
