Geforce FX 5200 upgrade?
Reply 20 of 28, by iraito
For a 2005\2006 i would go core 2 and an x700\x800 since you seem interested in those, the compatibility with win98 would drop but, do you care?
You can always put together an older machine with the 5200 that you still have and other unused parts.
If you wanna check a blue ball playing retro PC games
Reply 21 of 28, by Joseph_Joestar
iraito wrote on 2023-01-04, 18:05:
It's not so bad if he plans on dual booting Win98 and WinXP.
While Radeons don't support paletted textures and table fog under Win98, they can render table fog perfectly under WinXP with Catalyst 7.11 drivers and later. So, any games which use table fog can be played under XP. No such luck with paletted textures though, but that feature seems to be less commonly used.
PC#1: Pentium MMX 166 / Soyo SY-5BT / S3 Trio64V+ / Voodoo1 / OPTi 82C930 / AWE64 Gold / SC-155
PC#2: AthlonXP 1700+ / Abit KT7A / Voodoo3 / Audigy1 / Vortex2
PC#3: Athlon64 3400+ / Asus K8V-MX / 5900XT / Audigy1
PC#4: i5-3350P / MSI Z77A-G43 / GTX 650Ti / X-Fi
Reply 22 of 28, by iraito
Joseph_Joestar wrote on 2023-01-04, 18:46:
Yeah but i wouldn't use more than 512mb of ram on win9x, he would end up swapping ram etc. also the dual core might bring incompatibilities with some older game, overall if you want to stay in 2005\6 but also use win9x the system gets less flexible than let's say a 2004 and early 2005 machine.
Reply 23 of 28, by RandomStranger
That's completely normal. W9x and XP on the same PC is a difficult one and one has to compromise on both ends. Everyone getting into a project like that knows this already.
Reply 24 of 28, by SPBHM
amxcs wrote on 2023-01-04, 16:44:
Hmm.. https://i.imgur.com/6LD8dWv.gif […]
Hmm..
yep, this is a 64bits 333MHz DDR card, pretty low,
same memory bandwidth as a Voodoo 3
128bits 400MHz+ ram FX 5200 would be a lot faster, even if still not a great card.
Reply 25 of 28, by timsdf
Hmm..
Any of the cards listed previously ie. slower 9550, 9600 variants will be at least 2x performance upgrade to a 64bit FX5200. 😁
Reply 28 of 28, by iraito
amxcs wrote on 2023-01-06, 07:24:
I bought the video card from the first post and I am continuing the search for a better one at an acceptable price.
The card is Sapphire Atlantis 9600 128MB (11019-00) I'll try to overclock it if possible.
Better than that? a 9800 pro\XT\XXL if you want the top notch from that series, otherwise x700\x800 for the same compatability but way better performances.
