Beepblaster 1.0, 2.0 Wavetable Module
Reply 60 of 86, by dreamblaster
Ulfenknulfen wrote on 2023-01-06, 12:05:
Hi at all! […]
Hi at all!
Because i'm very ill, the Beepblaster is free for non commercial use!
Please have a look on my first Post.
best regards
Paddy
That is superb for the community ! Thanks.
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 61 of 86, by aspiringnobody
Reply 62 of 86, by aspiringnobody
Reply 63 of 86, by dreamblaster
it would be nice if the stereo support could run on one chip, maybe a larger avr chip ?
Reply 64 of 86, by aspiringnobody
Reply 65 of 86, by aspiringnobody
Reply 66 of 86, by dreamblaster
aspiringnobody wrote on 2023-01-07, 06:55:
I did a thing...
Serge if I send you the Eagle files can you look at this and let me know if there's anything obviously wrong? First time PCB maker 🤣.
- Evan
Hi Evan,
feel free to send me PM, i will try to help, but normally I use kicad, not eagle,
so my help may be limited to general comments.
I can already comment based on the screenshot :
I see you use the same ceramic resonator, shared for both cpu's, this can work fine.
But ceramic resonators are not that accurate (typically about 5000ppm, 0.5%),
and MIDI allows for a maximum of 1% tolerance on the clock frequency.
Crystals would be more accurate (typically 30ppm), but then you'd also need startup caps.
Layout wise it looks ok, i like the 'stereo' looks 😀 curious to see the other side.
Maybe you can upload screenshots of both sides of your board and also pdf of your schematic to vogons.
To avoid confusion though, it may be better to start a separate thread, and reference to ulfenknulfens thread as inspiration source ?
Looking forward to your further adventures !
Serge
Reply 67 of 86, by Ulfenknulfen
Hi Community!
The development of the Beepblaster 2.0 (Stereo with Beepmode) is ongoing and will be published here.
Of course I'll test it beforehand, so it will take a while.
Stay tuned.
best regards
Paddy
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0, 2.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️⌨🖱️USB HID Devices on PS/2 and Gameport.
Reply 68 of 86, by dreamblaster
Ulfenknulfen wrote on 2023-01-07, 08:22:
Hi Community! […]
Hi Community!
Stay tuned.
best regards
Paddy
Superb, very curious to see further evolution
if you'd use a larger cpu, maybe it can also have more voices ?
Reply 69 of 86, by SuperDeadite
Rise from your grave!
Used BeepBlaster with the newly released MSX game Rabbit Adventure.
Love this little guy, and hope I'll get to own a stereo BeepBlaster 2.0 someday. 😀
https://youtu.be/PYzxhn8G6ss?si=mfv-04Vg0WnBolf0
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 70 of 86, by dreamblaster
SuperDeadite wrote on 2023-12-03, 06:37:
Rise from your grave! Used BeepBlaster with the newly released MSX game Rabbit Adventure. Love this little guy, and hope I'l […]
sounds great !
Reply 71 of 86, by Ulfenknulfen
you got a message.
Happy new year to all!
best regards
Paddy
Reply 72 of 86, by Fagear
Hi! What fuses should be set to?
I've loaded *.hex into the programmer software, but fuses seem to be off, configured for internal RC with /8 clock divider enabled. And I see 16 MHz Xtal on the board.
Should fuses and firmware be the same on both MCUs?
New BIG soundcard: FMonster.
Covox Sound Master replica
Innovation SSI-2001 replica & DuoSID.
My audio/video collection.
Reply 73 of 86, by Ulfenknulfen
Hello Fagear.
Thanks for your Question.
Both Chips with same Firmware, and you can use e.g. these Fuses:
Best regards
Paddy
Reply 74 of 86, by Fagear
Ulfenknulfen wrote on 2024-06-14, 08:49:
Thanks! I'll flash MCUs and try the Beepblaster 2.0.
Reply 75 of 86, by Frank h aus l
hello my name is frank and i recently became aware of the beep blaster.
I wanted to build it, but I have two questions about it
in the partlist is r10 without a value
is it then 100 ohms? or what value is used here?
Is the socket J1 2x13 R 2.0 mm?
The card sounds great, I'm looking forward to a real reproduction.
Cheers
Reply 76 of 86, by Ulfenknulfen
Frank h aus l wrote on 2024-09-08, 07:57:
Cheers
Hello Frank.
Thanks for asking.
Beepblaster 1 (mono) has no R10. Just Beepblaster 2.0 has it, and it is in the Partlist 😀.
Socket is 2.54mm
best regards and have fun
Paddy
Reply 77 of 86, by dreamblaster
Amazing youtube demo of Beepblaster 2.0 by pc-sound-legacy
Stereo sound, and it sounds great !
https://youtu.be/cnJLOFmRATA?si=9z-p-XtPU7Ry1DHh
What a nice project 😀
Reply 78 of 86, by VideoGameRocker
So this one is DIY? Would love to buy one if its already assembled 😀
Reply 79 of 86, by MiDiGUy
dreamblaster wrote on 2024-09-11, 12:50:
Amazing youtube demo of Beepblaster 2.0 by pc-sound-legacy Stereo sound, and it sounds great ! https://youtu.be/cnJLOFmRATA?si […]
Yes it sounds really great, thanks for the link 😃👍
