Reply 21 of 22, by cambalinho
i found, finally, the open source-port Wolf4gw/Sod4gw: see the atachment files.
Moderator: i'm sharing for help the others using the Spear of Destiny or wolfteins3D... but if i can't, please tell me.
i need more help please:
1 - how i can change on Registry for get the open folder after reboot?
2 - what is the best browser for Windows 9X?
3 - is there a better program, than MS-DOS Sound Blaster Setter? https://retrosystemsrevival.blogspot.com/2019 … ter-setter.html
for get the sound card parameters. and use them on autoexec.bat
4 - how can i get more updates for KernelEx?
Reply 22 of 22, by Gmlb256
cambalinho wrote on 2023-01-05, 20:37:
no success :( please anyone can share me a wolf3D run file that works on windows 98? to be honest, i had 1, but i lose it :( i t […]
no success 🙁
to be honest, i had 1, but i lose it 🙁
i tried the line commands without success: https://tcrf.net/Wolfenstein_3D_%28DOS%29#Tec … port_Parameters
The original DOS version of Wolfenstein 3-D works fine in Windows 98 without using any command line switch or slowdown utilities, try testing with the shareware version instead.
cambalinho wrote on 2023-01-08, 17:04:
That source port is abandoned and was written with the purpose to eliminate real mode constrains. It got quickly replaced by Wolf4SDL which paved the way for the ECWolf source port.
It has Windows 98 support with the legacy version and can be downloaded at: https://maniacsvault.net/ecwolf/
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
