First post, by wbahnassi
- Oldbie
Hi guys, I have a TEAC FD-55GFR 5.25" floppy disk drive that is giving bad grinding sounds when its disk spin motor operates. The drive was super dusty, so I'm betting there are happy dust bunnies inside the motor 😅
Anyways, for the life of me I couldn't figure out how to disassemble the motor to clean it from the inside. I fully disassembled the drive except for the spin motor and its board. I removed all visible screws but both the board and the motor are still fixed to the drive.
The only screws I couldn't undo are the ones at the bottom of the motor plate. They are small but VERY strongly tightened. I just can't have them budge.
Anyone has experience disassembling this thing? Ultimately I just want to clean it and have its noise gone. I tried WD-40 bit found no improvements at all.
This is the motor I'm referring to:
Cheers!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
