deksar wrote on 2023-01-15, 17:15:By the way, VCore Voltage seems 1.60V for my CPU. Is this normal for a proc: Pentium 1.8A - 1.8 Ghz model SL63X 512 KB Cache? (Because SIV utility reports it in "red")
And CPU fan under SIV is reported as: 0 RPM, but BIOS supplies that info correctly; 2596 RPM.
Clearly Fan 2 is the CPU fan and I expect SIV reported Fan 1. Basically I need to adjust SIV to report Fan 2 as the CPU Fan. Please do Menu->File->Save Local and post to two generated files so I can adjust this and test the change. Please also post a screen shot of what the BIOS monitoring screen reports.
The CPU Core voltage is what the W83697HF reports and I suspect this is correct, but would need to check the save file to figure out why SIV defaulted to showing it in red. What does Menu->Tools->Configure->Highlight Setup report for the VIN voltages? If you change these and press [Apply] or [Save] the colour should change.
Given the GPU-0 P12 SIV must be using NVAPI rather than NVCPL. If you do SIV32X -NONVAPI then SIV should use NVCPL to try and get the temperature, does it succeed? If so I will adjust SIV in light of this.
The red blob to the right of Disks means SMART is reporting errors. Press the red blob then the right most push button to show all the SMART information.
