First post, by MaLLy_R
Dear Vogons.
I have an old Inswell turbo XT with this MFM HDD controller: http://mally.tim.com.pl/hdd_cont.jpg
It works OK with one ST225 drive.
But when i connect second drive PC doesn't seem to recognize it.
Wider cable has a proper twist (pins 6-10). http://mally.tim.com.pl/cable.jpg
Drive on straight connector has terminator removed and is set as "1"
Drive on twisted connector has terminator in place and is set as "2"
Both drives are the same ST225 and each one works ok when set as single drive.
What am I doing wrong.
I should change something on controller card?
Is it due to long cable? 60cm, 30cm between each connectors.
Please help.
MIDI. I like MIDI... A lot! (Also stuck in 8bit PC era)
Reply 1 of 13, by Ozzuneoj
Just throwing this out there... I don't know anything about this particular system. What wattage power supply does the system have and have you tried a different one?
I know on my IBM PC with the original 62.5W power supply it's so close to the limit with a 3.5" MFM hard drive, 5.25" and 3.5" floppies and multiple cards that the hard drive doesn't always initialize properly if I merely have the door locked shut on the 5.25 floppy because this makes it spin for a while during startup... Presumably drawing too much juice for the hard drive to function.
Most systems aren't this limited, but I figured it'd be worth mentioning.
Reply 2 of 13, by MaLLy_R
Ozzuneoj wrote on 2023-01-16, 14:03:
I don't think that's the case. I have got a 200W PSU here.
And its always not working on the twisted side of cable. I can swap drives i have same result "twisted one" don't work
Reply 3 of 13, by weedeewee
twisted ?
don't those drives have a common cable and a separate cable? No twist required.
the data cable being common, straight cable for all connectors
the control cable being separate per drive.
and maybe also a termination resistor to be removed.
a floppy drive "needs" a twist, but an mfm/rll drive... I doubt it.
Do not ask Why !
Reply 4 of 13, by MMaximus
weedeewee wrote on 2023-01-16, 16:35:
twisted ? […]
twisted ?
Not sure I can help OP - but I was recently setting up a NEC D5126 MFM drive, and it wouldn't initialise with a straight cable. It's only when I used a twisted cable that I managed to get it working 🤷
Hard Disk Sounds
Reply 5 of 13, by weedeewee
MMaximus wrote on 2023-01-16, 19:49:
twisted ? […]
twisted ?
I think I made a mistake, it's separate data cable per drive, and combined control cable.
so that would impy either jumpering the drive to the correct id, or have the cable with a twist.
https://arvutimuuseum.ee/th99/h/txt/4017.txt
JP7 seems to be the one
Do not ask Why !
Reply 6 of 13, by maxtherabbit
If you have the twisted cable, both drives must be jumpered the same
Reply 7 of 13, by MaLLy_R
weedeewee wrote on 2023-01-16, 21:04:
maxtherabbit wrote on 2023-01-17, 03:24:
Thank you, it helped a little.
Now PC sees two drives. But on second one (slave,twisted...) data is seen as garbage.
When i swap drives it sees only one drive.
What now? One of them is defective?
They both work properly in one drive configuration.
Reply 8 of 13, by Grzyb
http://www.uncreativelabs.de/th99/c/M-O/20151.htm
The DIP-switch settings on your photo are different than any of the settings listed there...
but the description isn't clear, we need the original manual.
Also, it would be a good idea to enter the LLF utility, and see what's in there...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 9 of 13, by MaLLy_R
Grzyb wrote on 2023-01-17, 09:46:
That is why i posted this photo. This is original setting that i got when i received this mashie.
I don't Know how it should be set.
Changing to:
4/612 (first one)
#2 - controller posts "logically partitioned hard disc"
#1 - system hangs while booting from HDD
4/612 (second one)
#2 - nothing changed, system boots, second disc is garbage.
#1 - "non system or disk error"
I didn't check it with LLF utility but CheckIT sees second drive (in two drives setup, when second drive gets recognized) as 11MB, so that's not right...
Reply 10 of 13, by Grzyb
ST-225 is 4 heads, 615 cyllinders
there's no exact match in the description, so 4/612 should be good enough...
Checkit reports a single drive as 4/612, right?
But I don't trust that description, eg. 4/1024 and 7/820 have the same settings...
The proper manual is a must, otherwise try all 256 combinations, or disassemble the BIOS and figure out how it reads drive parameters...
A wild guess:
it's possible that the switches 1..4 are for the first drive, and 5..8 for the second...
So, what happens when you set 5..8 exactly like 1..4 ?
Reply 11 of 13, by weedeewee
funny... the link I posted states CHS 615/4/17 precomp 300 LZ 670
nevermind, your link is about the controller 😁
Do not ask Why !
Reply 12 of 13, by MaLLy_R
Grzyb wrote on 2023-01-17, 15:56:
A wild guess:
It worked!
Both drives work!
Consider yourself my personal superhero.
Many thanks!
Reply 13 of 13, by Errius
What on earth are you going to do with so much storage? Host a MUD or BBS?
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
