First post, by tarik
Hello guys
I want to install windows 98 and windows xp two machines. I need your help.
Equipment I have. I'm curious about your processor and graphics card choices.
CPU:
Pentium 3 1000mhz / 384mb ram sdr 133mhz / agp slot
Pentium 4 3000mhz / 1gb ram ddr 400mhz / agp slot
Pentium dual-core e6700 3.20ghz / 2gb ram ddr2 667mhz / agp slot /pci-e slot
GPU:
NVIDIA
TNT2 M64 32MB ASUS
GeForce2 mx200 32MB ASUS
GeForce2 mx400 64mb
Geforce4 mx440 64mb 64bit WinFast LEADTEK
Geforce4 mx440 64mb 128bit MSI
Geforce4 mx4000 128mb WinFast LEADTEK
Geforce FX5500 256mb FLY
Geforce FX5600 256mb MSI
Geforce FX5700 256mb INNO3D TORNADO
HORSE
Rage Pro Ultra 16mb
Radeon 9250 256mb
Radeon 9550 256mb
Radeon 9600 XT 128mb
Radeon 9800 Pro 256mb
FireGL X3 256mb
Pentium 3 1000mhz, 512 mb sdr, voodoo3 3ooo win98
Pentium 4 2400 mhz, 512 mb ddr, geforce4 ti 4200 winMe
Pentium E6700, 2gb ddr2, Ati FireGL x3 AGP winXP
Reply 1 of 5, by Con 2 botones
Hello.
I (who lean to build with period correct parts) would pick the following:
PC 1 (Win98):
- Pentium 3 1000mhz / 384mb ram sdr 133mhz / agp slot
- Geforce4 mx440 64mb 128bit MSI
PC2 (WinXP):
- Pentium 4 3000mhz / 1gb ram ddr 400mhz / agp slot
- Radeon 9800 Pro 256mb
If you opted to build just one system to dual boot W98 and XP:
- Geforce FX5700 256mb INNO3D TORNADO
Reply 2 of 5, by RandomStranger
None of these make a very good XP PC.
is indeed decently balanced for W98. The FX5600 would be also good, but better suited for a faster CPU, but on the other hand, a fine choice for nGlide.
Is good for dual booting XP and W98. Won't be ideal for early W9x era compatibility, but it will be good enough, and it will be underpowered past 2005 games and lack compatibility once SM3.0 games start popping up.
In the meenwhile I'd look for a decent board for the E6700 and pick up something like a 9600GT or faster on the cheap. The reason for looking a better mobo for the Dual Core is that those combo boards almost always have only 4x PCI-e and can't run most graphics cards
Reply 3 of 5, by chinny22
Agree with above using the P3 for Win98, and your spoilt for graphic cards choice, personally I'd choose the FX5600 that way you can enable AA, AF, etc
XP faster is always better so would go with the dual core and best PCI-E card you have (I'm assuming the XP box doesn't need to dual boot into 98)
Reply 4 of 5, by tarik
Con 2 botones wrote on 2023-01-20, 15:05:
Hello. […]
Hello.
PC 1 (Win98):
PC2 (WinXP):
Thank you. I think this comment is very helpful and wise.
Reply 5 of 5, by tarik
Need a voodoo card for dos games? Or would it be geforce 4 mx 440? I'm asking for image quality. Would the radeon 9000 series be suitable for dos games and games up to 2002? I want antialising.
for windows 98
Pentium 3 1000mhz and radeon (9550, 9600 xt, 9800 pro)
