First post, by MigMig
It's been a litle while since I last used Glidos and the computer it was on long since kicked the bucket, so when I got the urge to pull out TR1 again I started fresh. I followed your excellent instalation instructions, downloaded the TR1 plus unfinished bussiness archive, downloaded a fresh version of glidos, got everything working, fed the new id into the unlock service, copied the four codes back into glidos, restarted glidos, and I still have the spinning logo!
I've double checked that the glidos ID is correct, evan going letter for letter, reset my computer, unlocked and restarted glidos two or three more times and nothing. I'm pretty stumped here.
Reply 1 of 7, by Glidos
Maybe Glidos is showing you one ID when you are on line unlocking, and another when you are off line playing TR1?
Also, try deleting the file authority.txt, and check that it is recreated by the unlocking process.
Reply 2 of 7, by MigMig
Well I'm on ADSL through a router so I'm on line all the time, and I tried it right after attempting to unlock, at any rate. I tried deleting Authority.txt, and it did reapear after I unlocked again, but I still have the spinning logo, evan after closing and restarting the program. I alos checked the contents of Authority.txt and it looks identicle to what the unlock service gave me back (I didn't check every letter though). My Glidos ID also hasn't changed in half a dozen or so attempts.
Reply 3 of 7, by Glidos
Post your Glidos ID and I'll have a look.
Reply 4 of 7, by MigMig
Sorry I took so long to answer. I've PMed you my Glidos ID. Thanks Paul.
Reply 5 of 7, by Glidos
I can't find any probelms specific to your ID.
The way the ID is derived has been changed in v1.38. Could you try v1.37
Reply 6 of 7, by MigMig
No luck I'm afraid. I've installed v1.37 (confirmed by the v1.37 tag visible in the main dialogue), but it produces the same Glidos ID and has the same problem.
Reply 7 of 7, by Glidos
We are missing something here. What you describe is near impossible.
Do you have access to another computer you could try installing to?
