Reply 47740 of 59321, by pan069
Another sound card, an Aztech Sound Galaxy NX Pro it seems. It think it is a SB PRO 2.0 compatible card. Anyhow, so far only cleaned (dishwasher + IPA) but not yet tested. I'll do that this weekend as we have a long one here downunder.
The attachment PXL_20230122_032112358.jpg is no longer available
Reply 47741 of 59321, by pete8475
BetaC wrote on 2023-01-25, 02:57:
Why would I want anything but RDRAM for a 1.3?
The performance would be far too good with that. 😁
aka pete4237.5
Reply 47742 of 59321, by pete8475
TrashPanda wrote on 2023-01-25, 03:11:
make sure you get the slowest RDRAM for it . .and dont forget a 64bit FX5200 just to round it out.
YES! This is good stuff.
aka pete4237.5
Reply 47743 of 59321, by Gmlb256
pete8475 wrote on 2023-01-25, 02:41:
Awesome, the worst one!
Are there socket 423 SD-RAM boards? 🤣
That would be a nice troll PC. 😁
Seriously though, RDRAM modules did have higher memory bandwidth at the time (DDR wasn't initially available) and gaming consoles used it too. Problem was that the company behind it (Rambus) had very insane demands.
Reply 47745 of 59321, by Shponglefan
pan069 wrote on 2023-01-25, 03:22:
edited: I stand corrected, it looks like it does have SB Pro compatibility.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 47746 of 59321, by BetaC
TrashPanda wrote on 2023-01-25, 03:37:
pete8475 wrote on 2023-01-25, 03:28:
I was going to suggest a Quantum Bigfoot as well but .. the parts are already cursed enough as is !
I do have a working Bigfoot.
Reply 47747 of 59321, by PcBytes
Yes - I have a MSI 845 Pro that's 423 + SDR, model number MS-6529.
file.php?mode=view&id=147532
file.php?mode=view&id=147534
Exactly same chipset, but 478 format, is on an AOpen AX4BS I recently bought at a car boot sale.
20230122_142008-jpg.280613
20230122_142014-jpg.280614
Reply 47749 of 59321, by BitWrangler
Yah, but what about a JTS Champion 😜
Reply 47750 of 59321, by H3nrik V!
BetaC wrote on 2023-01-25, 02:29:
I finally have something terrible, and I might someday build something around it.
Yeah baby, 1.3 GHz.
To experience just HOW slow the slowest of NetBurst could be 🤣
Reply 47751 of 59321, by Ozzuneoj
H3nrik V! wrote on 2023-01-25, 05:01:
I think this would be a good candidate system to test just how far you can take the oldest and slowest mainstream desktop CPU with SSE2.
Get the most RDRAM you can fit in it, the most recent PCI video card you can find (8400GS, 9400GT or something), an SSD and see what it can run. I haven't tried it, but apparently it is possible to install Windows 10 (32bit obviously) on CPUs that don't support NX bit. The biggest hurdle to running 10 on really old systems is that they need SSE2 instructions, which this has.
Reply 47752 of 59321, by BetaC
Ozzuneoj wrote on 2023-01-25, 05:18:
If I can find a motherboard at some point, I may just invoke this curse upon us all.
Reply 47753 of 59321, by Grzyb
Shponglefan wrote on 2023-01-25, 03:37:
The NX Pro is SB 2.0, not SB Pro compatible. It does have Disney Sound Source / Covox compatibility, so not a bad one to have.
SB Pro 2, stereo DAC + OPL3
And yes, it does support Covox and Disney.
The card was advertised as "Four cards in one": Adlib, SB, Covox, Disney.
Reply 47754 of 59321, by acl
BetaC wrote on 2023-01-25, 07:15:
And, please, add some AMR sound card. It would be a shame to have hardware accelerated audio.
PS : I have a 1.7Ghz Willammette at home. Working motherboards with i850 chipsets are quite hard to find. But i really love mine ! Look how great the RAM layout is ! https://retro.user-unfriendly.net/Parts/Mothe … 0727_225719.jpg
Reply 47755 of 59321, by HanJammer
What's more important about these cards is they have built in COVOX/Disney Sound compatibility.
Reply 47756 of 59321, by BitWrangler
Is it easy to get 2GB of RAM in a consumer RDRAM board though? Win10 will install on 1GB and "run" where the definition of "run" is like 98SE on 8MB or XP on 128MB... coz 1GB will be too pathetic to find out how pathetic it is, apart from some smaller benchmarks maybe.
At issue I think is the number of lines/lanes, it's like PCIe, you run out of them. I've seen 16 line 512MB chips, but most boards only take 32 max??? Not sure your chances on getting 1GB modules.
Edit: I think my head got infected with too many random dude on a forum explains of RDRAM back in the day, basically you have a 32 bit wide pipe, and up to two of them on a dual channel memory controller, and if you have 16 bit wide RDIMMs you need two of them per channel, or 32 bit wide you can have 1 per channel. i850 supports 2 32bit channels and 2GB.
Reply 47757 of 59321, by Shponglefan
Grzyb wrote on 2023-01-25, 09:54:
SB Pro 2, stereo DAC + OPL3 […]
I stand corrected. I was going by the information published in the chart on DOS Days which doesn't list SB Pro compatibility: http://dosdays.co.uk/topics/Manufacturers/aztech.php
Looks like that chart is in error.
Reply 47758 of 59321, by Kahenraz
Does anyone know for sure if it suffers from the reverse stereo bug found in many SB Pro implementations?
Reply 47759 of 59321, by Kahenraz
BetaC wrote on 2023-01-25, 03:46:
I remember thinking that I was speeding up my computer back in the day by putting the swap file on a dedicated drive. It was a Quantum Bigfoot...
