Reply 4040 of 5138, by EvieSigma
Somehow found this old Dell Optiplex GX100 in the e-waste bin at my hospital job in 2023...it's pretty rough but I felt compelled to save it anyway.
The attachment PXL_20230126_203720303.jpg is no longer available
Reply 4041 of 5138, by BitWrangler
Interesting, does it have some kind of fancy capture card for xray cameras in it or something?
edit: Ooooh, if it's still got it, might have some card for driving laser scanners.. which is pretty useless unless you've got one in the shed, BUT.. it might have a FPGA on it.. which, subject to a whole string of maybes, could possibly take hardware emulator code for MISTer or similar projects... when soldered onto another PCB tho.
Reply 4042 of 5138, by HanJammer
Some things I dug up in the basement I helped to clean, and guy let me take them away because they were destined to a scrap otherwise...
Floppy boxes are always welcome... Two of these already found a new owners...
Reply 4043 of 5138, by HanJammer
Motherboards I need to test, although I don't have high hopes.
CPUs are almost always OK...
And I tested the Graphic Adapters and all of them work fine. Nothing special, but the spare CT6710 will come in handy (I still have my original CT6710 from the 90s and it's good to have a spare just in case).
Reply 4044 of 5138, by HanJammer
Reply 4045 of 5138, by gerry
EvieSigma wrote on 2023-01-26, 21:43:
and rightly so! hopefully a fairly straightforward rescue
Reply 4047 of 5138, by HanJammer
gerry wrote on 2023-01-27, 15:09:
HanJammer wrote on 2023-01-27, 13:58:
3/3
all good things! hope that oscilloscope is working, they can be worth something too
Guy who wanted to get rid of it said it is working I didn't tested it yet though.
Reply 4048 of 5138, by BitWrangler
HanJammer wrote on 2023-01-27, 13:57:
2/3 […]
Quite a haul, congrats. Those ST cpus, I've messed with one or two back in the day, the impression they gave me was "What if there was a Cyrix, that was a cyrix to Cyrix?" i.e. cheaper and not quite as tight on quality. Meaning in effect that you need a good for the time heatsink and fan to keep it from crashing, while the Cyrix and IBM parts only needed the passive heatsinks.
Reply 4049 of 5138, by EvieSigma
gerry wrote on 2023-01-27, 15:08:
Unfortunately the case seems to be tweaked so much that the side panel won't even fit properly any more, but hopefully it still functions electronically at least.
Reply 4050 of 5138, by pbagain
BitWrangler wrote on 2023-01-27, 04:10:
The PACS stickers indeed seem to suggest that. If that's the case, more pictures EvieSigma.. pretty please 😉
Reply 4051 of 5138, by EvieSigma
pbagain wrote on 2023-01-27, 22:30:
Unfortunately it's been stripped of...basically everything by the time it ended up in my hands, no interesting cards...no cards at all, in fact.
Reply 4052 of 5138, by BitWrangler
Hmmm go careful testing it then, if retired gracefully it might have been more complete, if it failed in service, then the parts were needed to put in the new machine.
Reply 4053 of 5138, by douglar
I struck Beige!
The Oak VGA, Logitech Mouse card and Caviar 280 suggest an early '90s 486 or late 386.
The case, gigabyte-ga-586t2 mobo, K6-166 CPU and samsung hard drive seem 1997
The attachment Photo Jan 27 2023, 7 37 43 PM.jpg is no longer available
And then they upgraded to this heavy as hell Sony P4 a few years later. The case has a hole though the middle.
The attachment Photo Jan 27 2023, 8 49 31 PM.jpg is no longer available
Found them together in the snow with a generic Dell Core 2.
Looks like 30 years of computing history in a pile.
I'm going to wait until it dries off before testing
Reply 4054 of 5138, by BitWrangler
I didn't know they did a *squint* 12bit busmouse card, heh, probably just an extra IRQ or two to pick from.
Reply 4055 of 5138, by HanJammer
I got this Silverstone Raven RV01 case from a friend of mine (he wanted to trash it)
Also got this bunch of PSION organizers in various version from a daughter of an electronics professor who passed away due to COVID. All do seem to work. Apparently he was building some expansions because I also got a bunch of empty expansion shells and developer kits... It was again "You take it or I will throw it away" kind of a deal and she didn't wanted any money for it saying her father would be glad if somebody will have some fun with this stuff.
Reply 4056 of 5138, by BitWrangler
Think they've got a flat file database and also have been used for stock-keeping duties, so maybe useful to catalog parts on.
Reply 4057 of 5138, by chrismeyer6
HanJammer wrote on 2023-02-02, 15:00:
That's a very nice haul you got. Those cases are really nice and from what I remember rather easy to build in as well.
Reply 4058 of 5138, by HanJammer
chrismeyer6 wrote on 2023-02-02, 15:45:
I have an idea to use it in some not-so-modern build at work. Which I may do because the nice feature is the I/O ports are easily accessible from the top which may come in handy for the guys in the laboratories... We will see.
Reply 4059 of 5138, by BitWrangler
Trash picker alert, 20ns 4x64 SRAM "cache" spotted on 14.4 Fax modems, guess you'll need to find two of them and be okay with sub 33Mhz use... https://commons.wikimedia.org/wiki/File:Fax_M … Baud_AT-Bus.jpg
