First post, by boroda
I got a motherboard without bios, bios from here
https://theretroweb.com/motherboards/s/ecs-sl486ve#downloads
gave nothing. I'm looking for a bios dump from the same, obviously working motherboard.
Thanks in advance.
Reply 1 of 14, by Horun
Hmmm.. inside that bios is the strings:
40-0100-001131-00101111-121291-SIS-EISA.
AMIBIOS (C)1991 American Megatrends Inc., ..SL486VE V1.0 02-22-93.
So it should be the correct bios.
Reply 2 of 14, by CoffeeOne
boroda wrote on 2023-01-29, 16:26:
I got a motherboard without bios, bios from here https://theretroweb.com/motherboards/s/ecs-sl486ve#downloads gave nothing. I'm […]
Thanks in advance.
Where do you got this board from?
I assume somebody could not get the board running, and before trashing it, he/she removed the BIOS.
Reply 3 of 14, by PC Hoarder Patrol
Thanks in advance.
I have this (working) board - can probably dump the BIOS using the ROMSAVAT app from the GETROM archive
Reply 4 of 14, by Horun
PC Hoarder Patrol wrote on 2023-01-29, 22:23:
Thanks in advance.
That would be great if you could, also please specify the eeprom type/model. Thanks 😀
Also the board uses a DS1387 "ramafied" RTC and if like the DS1587 "serialized" for EISA will not allow a bootup if the battery is dead from my experience..
Reply 5 of 14, by boroda
CoffeeOne wrote on 2023-01-29, 17:21:
Thanks in advance.
Like all of us. I bought it at a flea market ... Yes, maybe so, but usually bios are removed for collection. I already desoldered Dallas, today the socket should come by mail, i will solder socket for Dallas. Repair to Dallas i already did, there was 3 volts, now 3.6 volts.
Reply 6 of 14, by boroda
I would be very grateful if this can be done.
Reply 7 of 14, by boroda
Yes!!! It was dead Dallas. Now the motherboard has started, so the BIOS is correct. )))
Reply 8 of 14, by PC Hoarder Patrol
boroda wrote on 2023-01-30, 14:15:
Glad you got it working again 😀 (was pretty sure my BIOS version was the same as the one on The Retro Web anyway) - if you need the EISA config app / files for the board, let me know
Reply 9 of 14, by boroda
PC Hoarder Patrol wrote on 2023-01-30, 16:16:
Thank you)) It's quite easy, i found them a long time ago))
Reply 10 of 14, by Horun
That is great ! Good work ! Glad you kept working on it to see it finally boot proper.
Can you take a good picture of your board and post it here ? And any other info you found about the SL 486VE that was hard to find would be nice too.
Reply 11 of 14, by PC Hoarder Patrol
Horun wrote on 2023-01-31, 02:20:
...any other info you found about the SL 486VE that was hard to find would be nice too.
Don't know if its the same as what @boroda might have, but I've left a post of what I've got (manual & EISA config) for the Retro Web team - Re: The Retro Web submissions thread: suggest edits and/or add new boards here
Reply 12 of 14, by Horun
Thanks !
Reply 13 of 14, by boroda
Yes, i'll try to take a photo tomorrow. And for not to make legends. I also found that my oscillator held in the socket miraculously. Perhaps Dallas did not require repair. But this action did not get worse and he now stands on the socket.
P.S. Pentium ODPR 83MHz runs ok.
Reply 14 of 14, by boroda
PC Hoarder Patrol wrote on 2023-01-31, 04:21:
I don't think i can add anything. You even have a scan of the original manual. Thanks, great job.
