Soyo 6ze+ bios savior
First post, by amijim
Hello vogoners, I am trying to revive my trusty soyo 6ze+ because it is a Soyo, and unfortunately while it was decommissioned in Working state, I found it trying to boot in boot block mode. It asks for a bios file and I tried successfully programming the bios using awdflash but the mobo does not post at all. I tried to program the bios on another mobo by hot plugging it and even though It was a successful task using uniflash 1,40 the motherboard posted correctly one time with some destroit colours and on every other try the mobo booted in boot block mode. The original bios chip is a mx28f2000tpc and I tried with the same outcome a winbond 49c020. It seems that the rom stored on the bios chip gets destroit. I measured the vcc to 5v and vpp to 12v. What else could cause a rom getting destroit? Any clue out there because it is a Soyo?
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 1 of 6, by Horun
Try flashing the bios again and remove all hard drives before booting up. There are known old virus/worms that can write to bios on older unprotected boards.
If still gets corrupted then it a board issue... just a quick thought.
Reply 3 of 6, by amijim
I will try tomorrow to flash the rom with flash rom. Thank you.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 4 of 6, by Repo Man11
Have you replaced the capacitors? Both Soyo boards I have had failing capacitors. I just checked on Ebay, and the one listing I saw for a 6ZE+ has some obviously bulging caps.
Reply 5 of 6, by amijim
Hello there, I bought a new bios chip and even though it is written mx 28f2000,it is recognised as 28f010.i believe it is a China fake chip where I can only write 128kb.i tried to program a w49c but writing fails. Does the chip kb arrangement is specific to the mx28f2000 only? Which chip is a direct replacement? The caps looks okey. The original chip was placed 180degreea differently and it got super hot yet it is recognised, uniflash programmes it okey yet award 535a fails to write it. The bios chip after uniflash programming only enters me in boot block mode. Any thoughts?
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 6 of 6, by amijim
So which bios chip is a direct replacement?
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
