Which USB 2.0 cards for old motherboards
Reply 200 of 393, by Sphere478
digger wrote on 2023-01-24, 22:23:
Indeed, thanks for pointing it out. They're expensive, though! […]
Kahenraz wrote on 2023-01-22, 18:48:
StarTech has USB 3.0 cards for PCI slots. Of note to others, there are no Windows 9x drivers for these cards.
Hopefully they can be had elsewhere for more reasonable prices, pre-owned for instance.
Any other brands that released USB 3.0 cards for legacy PCI slots?
You could make one with a low profile pcie and a pcie to pci adapter
Sphere's PCB projects.
Reply 201 of 393, by Kahenraz
I find it difficult to adapt low profile cards with these card edge adapters. The primary issue is that low profile brackets face the opposite direction. So to get it to adapt properly, with the bracket screwed into the case and the lid shut, you need to have a different bracket altogether.
So, the card edge gets adapted, but the bracket doesn't fit. That isn't all that helpful for any practical use.
Reply 202 of 393, by Sphere478
Kahenraz wrote on 2023-01-25, 05:33:
Yeah, I know, idk why they decided to reverse the screw location
Reply 203 of 393, by digger
In the case of a USB card, that might still be worked around if the bracket can be removed and the card has internal USB headers that would allow you to hook up a separate bracket or the USB ports integrated in the ATX case. But yeah, a legacy PCI card without such an adapter would indeed be much more practical.
Reply 204 of 393, by Kahenraz
At least we can 3D print our own brackets now.
Reply 205 of 393, by Sphere478
Kahenraz wrote on 2023-01-25, 15:41:
Calamitylime made a pcb bracket also.
Reply 207 of 393, by lti
Sphere478 wrote on 2023-01-21, 18:36:
They slow down the system just by being installed. I’m not going benchmarks while copying files 🤣. :p that would make sense if that was the problem.
No, just by being installed they slow the system down.
The VT6212 card I mentioned didn't seem to slow the system down until a device was plugged into it. Even a mouse would totally kill performance (like 85% CPU usage at idle on a K6-2/500).
At least the card I have (a Rosewill RC-100) has an internal USB header. The problem with that card is that it has jumpers over the fuse positions on the power pins for each port, and it only uses half of the 5V pins in the PCI slot. I installed 750mA resettable fuses, but I haven't tested it to see if that current rating is acceptable (500mA is a little too low for external hard drives, but I don't want to toast the PCI connector - I guess it will just get a little warm at full current).
Reply 208 of 393, by tauro
Recently I got a card with a NEC D72010XF1 chip. It looks cool with that IHS. The board is from October 2010 so it's a "very new" old card.
I didn't find any datasheet about this particular "XF1" chip but I guess it's part of the D72010(1) family. Perhaps the latest iteration? I still haven't tried it.
Reply 209 of 393, by Kahenraz
Off the top of my head, I think the latest non-laptop chips were the small square BGA ones. Often there will be a gigantic square silkscreen around it, indicating that the PCB was originally designed for the larger node with a larger package.
I think this is the result of a die shrink and refinements with the use of a revised PCB.
Another great comparison is the ESS Maestro-1 vs Maestro-2.
Reply 210 of 393, by Sphere478
tauro wrote on 2023-02-03, 17:14:
Oh that’s very interesting.
Look forward to results of speed tests on old systems
Reply 211 of 393, by schlang
where?
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 212 of 393, by ediflorianUS
I mounted A VIA one in my 80486 and it works fine. (* VIAUSB20 - black PCB , 3xUSB ports back and one inside).
My 80486-S i66 Project
Reply 213 of 393, by psybyrd
USB 2.0 = a resource hog in 98se. From my experience, NEC cards work great if you can get them to stop sharing IRQ's with other devices.
Reply 214 of 393, by Kahenraz
Maybe that's why it's so unstable for me. I'll have to look into that.
Reply 215 of 393, by tauro
psybyrd wrote on 2023-02-07, 22:00:
Would you please elaborate more on this? Do you have any more info?
Reply 216 of 393, by tauro
Sphere478 wrote on 2023-02-04, 17:01:
I plan to test this card and a VIA and ALi soon, on a socket 7 system and on a powerful socket 370 system and see what happens... both on Win98 and on Linux. I don't expect huge differences but we'll see. I'll do it and post the results when I get around to it, it's coming down the pike.
Reply 217 of 393, by Stevogamer
Back in the day I used an NEC based USB 2.0 card on my BH6. It seemed like the VIA chips always caused me issues just threw a bootloop.
Reply 218 of 393, by stanwebber
i have the startech card. are win98 drivers impossible or did renesas (nec) set an arbitrary cutoff so they wouldn't have to support it? i kinda been waiting for someone to mod the drivers. it's a nice card...4 ports and even low profile.
Reply 219 of 393, by m87
I've had bad luck with VIA based cards with my P5Hx-B & P200 MMX. I recently bought two old stock USB 1.1 & 2.0 pci cards boxed and complete with drivers for 98. One is ALI based, the other NEC. Hopefully I'll have luck with one of these.
(A chronos card and a Swann card, respectively)
