Reply 23660 of 31603, by Nexxen
Ozzuneoj wrote on 2023-02-04, 01:26:
Nexxen wrote on 2023-02-03, 22:37:
5th yields the beep of missing ram. I turn off the PSU: 3 caps explode!
Oh man! That's never fun! 🤣 🤣
Motherboard or PSU caps?
Caps!
After removing all the dead caps they still have some life but are around 1200 instead of 1600 (I doubt they are alive at all but I checked anyway).
The last one of that kind (tall, 2,5 x 1 cm) was still good and had a higher reading with close to no loss. I put it back (it was on the CPU VRM zone)
They all were around the 12V 4-pin connector and I just didn't plug it in.
Board booted fine. Could access the BIOS.
I didn't stress anything after that but it caught me by surprise so much I was shaking for a minute 😀 heart pounding 🤣
The exploded 1st - micro pause- 2nd/3rd almost together.
It was a lot of noise!
Wish I knew why the pause and why they exploded when I turned off the PSU (I think it was just a coincidence, when they got enough charge to blow they blew).
The board wasn't booting because one of the caps got shorted (anti short PSU feature), my idea.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 23661 of 31603, by Joseph_Joestar
I remembered that Acronis True Image version 8 offered backing up over the network, so I decided to try it on my new retro LAN. Sure enough, it worked without a hitch. I easily imaged my DOS/Win95 machine to a network share.
This will come in handy when I want to test stuff out without the need to reinstall the entire system.
My retro builds
Reply 23662 of 31603, by Ozzuneoj
Nexxen wrote on 2023-02-04, 14:33:
Caps! After removing all the dead caps they still have some life but are around 1200 instead of 1600 (I doubt they are alive at […]
Caps!
Caps seem to blow at very strange times.
I remember 20+ years ago some caps in the power supply of my Brother's PC exploded when the system was turned off. It was ATX, so I know they're never truly "off" in the sense that an AT PSU can be switched off, but it still seems weird that any cap explosions I have experienced occurred when the PC was under no load or low load.
Reply 23663 of 31603, by Shponglefan
Demetrio wrote on 2023-02-04, 07:11:
Made a 386SX build. […]
Made a 386SX build.
Unfortunately, the HDD does not work so I have to wait the new one I've ordered to install MS-DOS 5.0
I will also buy a CRT monitor for it, like this IBM
That looks like a lovely setup. I'm really digging that case!
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 23664 of 31603, by Shponglefan
Gutted this generic Quantex system I got last year and set it up with a Intel 430TX motherboard + Pentium MMX 200 processor, along with a Hercules Terminator paired with a Diamond Monster 3D video card setup.
I may turn this into a DOS build focused on early 3D / Glide gaming. The case does have some rust, so it's going to first need a rust removal bath + some general cleaning first.
Reply 23665 of 31603, by Kahenraz
Oh, wow. I really like that case. The copper heatsink is also really nice. The layout is very clean.
Reply 23666 of 31603, by Gmlb256
Shponglefan wrote on 2023-02-05, 02:08:
I don't see the 3dfx card in PCI device listing which should appear as "Multimedia Device" with IRQ set as NA. Did you tested it prior installing the card?
Reply 23667 of 31603, by BitWrangler
I'm hung up in analysis paralysis mode of wanting to do like 5 things at once, but not picking what to do first.
Option A: Dig out the AST Advantage 386/25 and R&R it, throw in a soundblaster and CD, get it tuned up, find the Logitech Wingman and play Wing Commander, Keens etc..
Option B: Sort out the PC300/330 (Hell I don't know if IBM even decided which it was) 6571 with DX2-66 and play The Patrician, Battle Isle II. Install RealMagic card and try "Multimedia Space Explorer" and maybe see if 20Mhz bus with the caches turned off is Wing Commander speed too.
Option C: Excavate the Compaq Deskpro 233MMX stick either the Banshee or RV2100 in it, play Broken Sword, dick with multimedia stuff, try the 170 in one tweaks and see if it plays any of the crap previously mentioned.
Option D: ditto with Micron P233 tower, but it needs a soundcard finding prolly.
Having chosen one of the above, do light and tight with a 15" 4:3 LCD, or fishbowl CRT 14" with large dot pitch, not sure it does 800x600 even, but I kinda wanna see some stuff like Lost Vikings, Bio Menace etc on it to appreciate the bug is a feature antialiasing of the pixel sprites, and bask in the glow. or actually not too bad 15" that's crisper does 1024x768 for a more premium early 90s feel, still a little free AA, actually the smaller CRT option too, or 17" bit curvy lower end IBM G series, that is handiest to get to, not super crisp, might do more "free AA" than the 15", or full premium mid/late Trinitron IBM P series 17", that should be crisp and sharp best for windows stuff, but pixel art graphics look just as jaggy as on LCDs.... or say screw it and basically lose a whole quadrant of a room to the 21" Qvision, but hey I can kick back in a gravity chair with wingman on a plank and pretend it's a cockpit setup. ... or there's a projector... aaagh shut up brain, stop thinking of more alternatives.
Yah so mostly I've been digging out some old CDROMs and obsessing over system configs for playing them "just so"
Reply 23668 of 31603, by Shponglefan
Gmlb256 wrote on 2023-02-05, 03:19:
This is the first time I'm testing the card. I think that initial boot-up shot was taken without the card installed.
I did have a second shot on my phone after installing and it shows up.
Reply 23669 of 31603, by Shponglefan
Kahenraz wrote on 2023-02-05, 02:49:
Thank you! I'm hoping it will clean up nicely once I can get it fully de-rusted and wiped down.
Just started the rust removal soak.
Reply 23670 of 31603, by Demetrio
Shponglefan wrote on 2023-02-05, 02:02:
Made a 386SX build.
Thanks 🙂
I have to cover the slot for the CD-ROM, though 😅
Reply 23671 of 31603, by PTherapist
Today's retro activity for me was finally starting to capture some recordings from old VHS tapes that I found last year, utilising a bunch of retro hardware.
I grabbed the nearest PC to hand - an Intel Core 2 Quad Q6600 with 4GB RAM, running Windows 7 and installed a spare PCI Analogue capture card, the Hauppauge WinTV PVR-150. This card isn't particularly amazing, but it's what I had to hand and at least has hardware MPEG-2 encoding. A lot of people had driver issues with this card back in the day, but it's never let me down and seems to work absolutely fine in Win 7 x64 with 4GB RAM.
So to sum up, I used a 16-year old PC together with an 18-year old Analogue capture card, to capture footage from a 20-year old VHS tape using a 21+ year old VCR. The recordings were captured onto a 19-year old IDE HDD, just for the added retro factor. 🤣
Retro hardware can still be very useful many years later.
Reply 23672 of 31603, by BitWrangler
PTherapist wrote on 2023-02-05, 17:39:
Today's retro activity for me was finally starting to capture some recordings from old VHS tapes that I found last year, utilisi […]
Nice, sounds like it was fairly trouble free? I am pondering doing some of this eventually. Have a PVR-150, but also the later 1250 that has ATSC, wondering though if 150 is better choice because all the money is in the analog tuner, vs 1250 where it's more 2nd fiddle, or maybe it uses a newer/better chip. However, I have compro video mate, ATI TV wonder, something by Avermedia, VIVO Geforce cards, and usb capture dongles, which is more like too much choice, just would be nice to hit the ideal combo first go.
Reply 23673 of 31603, by Murugan
Converted this sadly non-working XT to a working 286-16. I just kept the case and PSU,all the rest are spare parts.
Reply 23674 of 31603, by BitWrangler
Kind of a traditional move, though shame the XT board wouldn't work for you.
Reply 23675 of 31603, by PTherapist
BitWrangler wrote on 2023-02-05, 18:01:
Yeah it was pretty trouble free. The drivers for the PVR-150 are still easy to find online, as well as the WinTV 7 iso image.
As for what to go with, with all that choice it's probably best to experiment. The PVR-150 was always a budget model, so the 1250 or 1 of those other products may well produce better results. The MPEG-2 encoding of the PVR-150 is not amazing, I always found it a little smeary as if the denoise filter is being applied slightly too harshly, but it gets the job done.
Reply 23676 of 31603, by Murugan
BitWrangler wrote on 2023-02-06, 01:55:
Yeah I know.
Tried a few things but nada.
Both the controllers report to be dead too so I'd thought that transplanting would be the next best thing.
Still going to check the hard drive though once I find my spare controllers.
Reply 23677 of 31603, by GigAHerZ
Over the weekend, took my 486 apart and once-and-for-all got it stable and fully functional.
It's a VLB based machine, running at 3x50MHz. The io controller and S3 Trio32 are fine with 50MHz VLB bus, but for RAM i had to go from "Fastest" -> "Faster" -> "Slower" setting for timings, otherwise it tended to crash on Doom and Duke3d and had vertexes jumping into random places with PC Player benchmark.
I'm also using URAM+HIMEM for UMA/HMA memory and had to take the "lowdma" from UMBPCI package to get my floppy drives properly working.
Now the machine is pretty much complete - there's not much i could wish for a super-high-end VLB-based 486...
Reply 23678 of 31603, by 80386SX
Murugan wrote on 2023-02-05, 20:04:
Very nice monolithic case, love it.
Reply 23679 of 31603, by Murugan
Love it too 😀
It's like a huge brick and it's in REALLY good condition for being this old.
