Amstrad 5.25 floppy drive compatible with 386?
Reply 20 of 66, by Errius
I think in these old computers the 5.25" drive was usually configured as A: and the 3.5" as B:
Can you show a picture of the BIOS floppy settings?
"AI Requires Proof That You Are Human"
Reply 21 of 66, by Nemo1985
I kindly disagree, what decide what is A: and B: is how flppy are connected, I tried to set the 1.44mb as b and I get an error message.
The attachment 0001.jpg is no longer available
Error:
The attachment 002.jpg is no longer available
My settings (no error but the problem described before):
The attachment 003.jpg is no longer available
I have been told that the problem could be a drity data bus, I tried to clean the card contacts with pencil eraser, change the isa slot, disconnect the serial\parallel port but no changes.
Reply 22 of 66, by Errius
What happens if you use the original black 3.5" drive?
Reply 23 of 66, by Nemo1985
Nothing, I can set it as 720 or 1,44mb the led turns on but it doesn't read the floppy (I have 1,44mb floppies only).
Reply 24 of 66, by Errius
Do you have any other floppy cables? I suspect that PCB adapter is causing the problem.
Reply 25 of 66, by Nemo1985
I do, but that would make 2 floppy cables non working, since with my floppy drive I use my floppy cable, I do not know if I have more because most of them have a pin with closed hole while such cards have all the pins.
Edit: tried a third floppy cable with another floppy drive, same behaviour... not boot disk with weird characters.
The problem is somewhere else
Reply 26 of 66, by Errius
OK, you're not using the PCB. (I was trying to figure out what those jumpers on the PCB do.)
No key means cable might be oriented incorrectly. Make sure the red wire is closest to pin 1.
Reply 27 of 66, by Nemo1985
Thank you, the cable is properly connected.
I may give a completely different try.
I have an ISA floppy ide card, that wouldn't make the original hard drive works but it would let me verify if the problem lies on the mfm\floppy card or on the pc itself.
Reply 28 of 66, by Nemo1985
Bad news everyone!I installed the isa card with cf adapter, thanks to xtide I was able to boot the cf card, pc seems to work fine in such configuration...
Now... any suggestion? Is the mfm card broken then?
Reply 29 of 66, by Errius
Can you show us the floppy and hard drive controller cards? Are there any jumpers on the floppy card?
Reply 30 of 66, by Nemo1985
The controller card is an Everex EV-332. I found the settings here:
https://stason.org/TULARC/pc/hard-disk-floppy … ves-EV-332.html
There are no populated jumpers, it has 3 cables:
J1, J2 and J4
From what I understood J1 and J2 are cables that need to be connected to the hard drive, while J4 is for the floppy drives.
I tried to connect my surely working floppy drive to that card and it doesn't work.
To me the problem seem the card, that being said it's in pristine visual condition, here is a picture:
The attachment IMG_20230206_223322_cr.jpg is no longer available
Reply 31 of 66, by Errius
Problem is, if you replace the controller card you will lose all data on the hard drive.
Have you tried putting the original 5.25" drive back, i.e. everything in original condition? Maybe it needs the two floppy drives, IDK.
Get hold of DD 3.5 floppy disks and see if the black drive works with them. Also see if you can get the system to boot off the 5.25" drive.
Install batteries too.
Reply 32 of 66, by Nemo1985
I'm actually unable to do any other try because while trying to get the cpu in the socket (after take it out to clean the contacts), I've broken an address pin line of the cpu.
Now the computer is obviously dead.
Reply 33 of 66, by Errius
L O L, too bad. I recently broke a pin on a 1.4 GHz Tualatin Celeron removing it from a system, which annoyed me greatly as these things are no longer cheap. However it's only a corner VSS pin so it should still work OK.
Reply 34 of 66, by Nemo1985
yes and if you have the skill you can replace it, while for the 286 it's impossible, I already ordered a replacement btw.
Reply 35 of 66, by Nemo1985
So we are back on business good people.
Where we were?
The mfm card seems to be the problem since with an eide sd card the pc booted fine without any visual glitch.
It's the only mfm card that I have (and do not plan to buy another just for this pc).
Any test I can do to check the mfm card only?
Reply 36 of 66, by weedeewee
Nemo1985 wrote on 2023-02-07, 20:59:
While the pin is broken off, you can still solder a new pin to the side of the chip where the broken off pin was located. while it won't be very sturdy, it should make the cpu still usable.
easiest way to solder it on would be to put the cpu back in the socket, put a piece of wire, like the cut off leg of a new resistor or new capacitor, in the socket where the broken pin was
and solder it to the side of the cpu.
There will always be some metal left to solder it onto.
Do not ask Why !
Reply 37 of 66, by Nemo1985
I already bought a new 286 cpu and mounted it, the old one had almost none metal left on the broken pin:
The attachment IMG_20230221_222428_cr.jpg is no longer available
Reply 38 of 66, by rasz_pl
plenty of metal left for a fix - you dremel out the plastic above to uncover it 😀
Reply 39 of 66, by Nemo1985
rasz_pl wrote on 2023-02-22, 01:49:
With the new cpu the behaviour is even more erratic, most of the times the pc doesn't boot, the diagnostic card throws random numbers, while with the old cpu it was booting consistently.
If I ship the cpu to you, would you repair it, please?
