First post, by pentiumspeed
I'm having no luck finding datasheet pdf for these two chipset, very important to decipher the odd 486 SBC I have so I know their jumpers purpose since the original maker was been disbanded and data lost when owner retired in 2015.
I need datasheets on these chips for Chips & Technologies two chipset F84021 and F84025.
I tried google with no luck.
Cheers,
Great Northern aka Canada.
Reply 1 of 6, by Horun
Well AFAIK some of the C&T chipsets the datasheets were kept in house..
Only thing I found was a "Prelim" mentioning 4021 and 4025 as part of the C&T CS4000 "WinChips" chipset and 84021 Bus/Dram controller and 84025 Data buffer..
https://www.datasheetarchive.com/pdf/download … 2520for%2520486
There may be some similarity to the 4031/4035 chipset....
added: if same as this: Micro Industries 486HS with PC104 and ISA SBC any information?
or from: Warning about Micro Industries SBCs. They are propietary in firmware!
Did you buy another ??? My suggestion: Do Not buy anything that is from that company, but think you already said that in the other thread 😀
Reply 2 of 6, by Horun
Update, this is best I could find after going thru a bunch. The cs4021 and cs4025 pinout and descriptions are in this:
https://www.datasheetarchive.com/pdf/download … 6DX%2520chipset
Reply 3 of 6, by Horun
Did the chipset datasheets help ? I looked around but found no motherboard bios with cs4021+4025 and the 82c735.
This one would probably work if a BIOS could be found....https://theretroweb.com/motherboards/s/diamond-fastbus-vlb
Reply 4 of 6, by pentiumspeed
That what I considered too. But good question on finding this ROM firmware for this Diamond fast bus board.
Chipset datasheet is somewhat helpful but does not mention anything about the jumpers. I have known one jumper is for the watchdog IC using MAX. SBC boards commonly use watchdog circuitry either is disabled or enabled via jumper.
Cheers,
Reply 5 of 6, by Horun
What is the numbering on the Intel chip near CPU and BIOS ? hard for me to read (bad eyes 🤣)
