First post, by djsabreblade
Well I thought I was getting 144hz in full screen mode but apparently not. 144hz works in desktop mode (in windowed mode i get 144+fps in games) but any game in full screen mode limits me at 75hz. Both fraps and my monitor display 75hz instead of 144. Yes I have tried changing settings in amd catalyst 14.4 but it just doesn't work. On this exact same hardware on windows 7 64 bit i get 144hz in all games with no issues. I am using a Lenovo G27-20 monitor and 7970 matrix platinum. is there any way to force 144hz in full screen on xp?
Duron 800mhz 256mb ram geforce2 mx Windows 98se
K8V-MX/S Sempron 2600+ 512mb Ram Radeon 9600XT 256mb Windows XP Pro Service Pack 2
djsabreblade.bandcamp.com
Reply 1 of 11, by DosFreak
GPU drivers on XP only support HBR1. You need to find a custom resolution and refresh rate that you are happy with within the limit. If you want 144hz then lower the resolution.
Make your games work offline
Reply 2 of 11, by djsabreblade
I'm only using 1080p, is that too high for 144hz?
Reply 3 of 11, by DosFreak
Try it and see.
If you still can't go higher but you are within HBR1 spec then you can try tools like refreshlock to force a higher refresh rate.
Reply 4 of 11, by djsabreblade
You're right. I can only go up to 1680x1050 with 144hz on windows xp. oh well at least i can game at 144hz 1920x1080 on windows 7.
Reply 5 of 11, by djsabreblade
One more question please, why does my monitor display 144hz at 1920x1080p on the desktop but as soon as I switch to fullscreen directx3d mode at that resolution it can only handle 75hz? It almost sounds like a driver limitation, because on windows xp (at least for me) full screen OpenGL mode at 1920x1080 does work at 144hz. All games that use direct3d with the 14.4 drivers can only do 144hz at 1680x1050. So this is a direct3d driver problem that was never fixed for Xp? thanks. 😀
Reply 7 of 11, by djsabreblade
A few times i restarted the computer on Xp and Catalyst complained (error message) about the display port cable not being able to handle the resolution or something. So I ordered a new cable from amazon (i ordered one before but i got a refund because UPS lost it). Not sure if it will make a difference though because Windows 7-64 seems to have no problems with the cable except the only issue i have is i cannot oc my card at 144hz. At 120hz and below overclocking does work however. I can oc on Xp at 144hz but can't go past 1170mhz on the core. So maybe its a cable issue.
Reply 8 of 11, by agent_x007
OS = Windows XP SP3 x86
915.15 KiB
1.03 MiB
1009.64 KiB
GPU : ASUS R9 280X 3GB "TOP", using Display Port to Display Port cable.
Driver : Catalyst 14.4 "pack 2" (source : LINK)
Caution 1 : CCC has separate option for forcing selected refresh rate under fullscreen (3D Refresh Rate Override option).
Caution 2 : CCC has option to hide refresh rates it thinks your monitor can't support (can by bypassed forcing all modes to be available).
1.27 MiB
Reply 9 of 11, by LSS10999
I'm not sure about Catalyst (CCC), but with nVidia you most likely would have to write your own timings to get higher refresh rate on XP. This page would be helpful for those who want to set up custom timings, be it for video card, or EDID emulators.
On WinXP there is a setting for 1080p/120Hz with my Quadro, but the output is messed up. If I create a custom resolution for 1080p/120Hz using CVT-RB timing then I get a proper 120Hz output.
As for 144Hz... I don't think it would be viable. With just HBR1/HDMI 1.4 bandwidth, you need at least CVT-RBv2 to keep it within the clock limit (340MHz).
Not sure if the ability to add custom resolution is possible with consumer (Radeon/GeForce) cards. At least I know that the ability to load/lock a (modded) EDID is exclusive to workstation (FirePro/Quadro) cards.
Reply 10 of 11, by djsabreblade
thanks guys i bought a new cable if that doesn't work i'll have to be happy with 1680x1050 centered timing 144hz.
desktop mode works at 144hz 1920x1080
fullscreen opengl works at 144hz 1920x1080
the highest i can get d3d games to work at 144hz is 1680x1050
i can't even get d3d games to run 1920x1080 at 100hz or 120hz only 75hz works, that's why i think it might be the stock cable that is causing these issues
Reply 11 of 11, by djsabreblade
Edit!
I got it working with RefreshLock. Lol!
