Sabre Team won't execute
Reply 20 of 29, by red_avatar
Which version is it? CD? Disk? Did you download it?
Reply 21 of 29, by greenr18
for Sabre Team? I'm using files I directly copied from my Sabre Team CD. I installed from the CD and it didn't work so I copied 'em to hard drive and it didn't work, sooo... yeah it's from the Sabre Team CD.
Reply 22 of 29, by red_avatar
Make sure you installed them from the CD - copying them will give it a read only tag.
Reply 23 of 29, by greenr18
great now it won't let me mount my D: drive it says directory d does not exist... I have a sneaking suspicion that Dosbox hates me
Reply 24 of 29, by red_avatar
Maybe you're just doing something critical wrong 😜
Reply 25 of 29, by greenr18
(humorous tone) ELABORATE, vile fiend!
ok, tell me everything YOU typed in to get sabre team to work then
***omfg i finally got D mounted and typed install and nothing happened it jus acted as if something WERE going to happen (so I assumed it did install it to C) and it didn't.
my question now is, what does dosbox run from i mean maybe this is going to sound stupid but do i need the latest java or something like that? does dos box require service pack 2 for XP?
Reply 26 of 29, by red_avatar
Besides Dosbox itself you don't need anything. It really sounds as if something is really wrong. Maybe a bad Dosbox? Try a different version.
Reply 27 of 29, by greenr18
I tried .065 it didnt work. ill try .70
ok .70 did not work, nor did .71 or .65
You know what, I quit.
Reply 28 of 29, by MiniMax
Rank Moderator
Moderator
Probably a wise decision.
_________________
Reply 29 of 29, by greenr18
Oh my $%^&*^# God, I got it to work! I borrowed a friend's floppy disk set and somehow that worked 🤣 well that was horrible and frustrating, thanks for the help people.
