TrashPanda wrote on 2023-02-17, 13:50:But we know that this isnt exactly true ...I mean all the 286/386/486 boards with Varta batteries that haven't been used/charged […]
The Serpent Rider wrote on 2023-02-17, 13:47:
So apparently these don't leak if no charge is applied, based on my sample size of one.
I have a few boards with pristine looking batteries. That condition never changed after few years of laying around in my possession. So yeah, no charge = no destructive chemical reaction.
But we know that this isnt exactly true ...I mean all the 286/386/486 boards with Varta batteries that haven't been used/charged in decades all with massive corrosion from leaking Varta batteries.
Unless you are being sarcastic, given up trying to tell with your posts 🤣.
Only batteries I don't see leaking are the CR lithium cells . .which don't get charged ..I guess if you consider that then your post is correct.
Depends on the definition of "no chemical reaction" and "empty" 😀
(1: at 0 V the electrochemical reaction has fully completed, but probably not all the products - or the reagents, as they're probably not precisely matched by mass - are inert with regards to the shell;
2: the usual "0% depends on the application but is more than 0 V")
FWIW I've never seen a nickel battery leak in a computer (in person, that is - plenty of photos from here or "uh I can't be bothered to find a power cable to try this" sellers!), but more than once in totaled furnace mechanical timers, the difference being that in the latter it never really spent tens of months empty, so while there may still be a correlation with charge level it's not most of the story!
Did have a leaking NiMH and CR2032 though 😀
Nowadays, gray market chinesium batteries (including zinc-carbon, the original cheapo leak fests) may outlast, on this point, major brands' heavy-metal-free alkalines - not the first time pandering to illegal dumpers has noticeably worsened product quality...
