First post, by Augustus Blizzard
Hello!
The problem: When I change to full screen in DosBox, the screen turns black, stays like that for a while until a quick BSoD flashes and the computer restarts itself. The program seems to run normally in windowed mode, and when I put "fullscreen=true" in the conf file, it just used the windowed mode and filled the rest of the screen with black... so it's not true full screen at all. And I would really like it being true full screen 😀
So is there some way to find out why the program crashes like that? Or a magical fix? Solutions?
My specs:
Pentium IV 2.66 ghz
1536 MB RAM
XFX nVidia Geforce 8600GT 256 MB RAM
Sound Blaster Audigy 2 ZS
Windows XP Home Edition
Thanks in advance.
Reply 2 of 11, by wd
Rank DOSBox Author
DOSBox Author
[moved]
Reply 3 of 11, by Augustus Blizzard
Reply 4 of 11, by DosFreak
Turn off "Automatically restart" in your My Computer - properties and then replicate the behavior that causes the BSOD. Instead of rebooting the computer should stay on the BSOD screen so you can identify what caused the crash.
Make your games work offline
Reply 5 of 11, by Augustus Blizzard
Hm, apparently it was nv4_disp so it could be a GPU-related issue... I've updated to the latest drivers, though.
Reply 6 of 11, by ADDiCT
I think there's no way a properly coded app can crash your OS like that. Do you have the graphics card or your CPU overclocked? I've seen these "spontaneous reboots" on machines with broken RAM modules, or from machines that were incorrectly OC'd. Another source of that kind of problems could be old/incorrect AGP drivers.
Reply 7 of 11, by eL_PuSHeR
AGP implementation sucked since first time it was devised. My ATi Radeon X800GTO tends to crash sometimes when AGP aperture is set to >128MB in bios. It's a pity, because setting AGP aperture to 256MB gives you a slight boost in fps.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 11, by Augustus Blizzard
No, I've never overclocked a thing and my card's PCI-E.
Well bummer if there's no solution. I guess I have to wait for new drivers or something. :\
Reply 9 of 11, by wd
Rank DOSBox Author
DOSBox Author
Try core=normal and cycles=1000.
And check your memory with memtest.
Reply 10 of 11, by Augustus Blizzard
Not working... and memtest didn't bring up anything either. :\
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
Maybe downgrade the video drivers then, and keep an eye on overheated components.
