Best 386 Motherboard?
Reply 280 of 287, by 386_junkie
luckybob wrote:
That solution wont work in an IBM. Well, as long as you want to use more than 2 simms. Also the board only supports 1MB simms. If I want to use the 5-16mb range, I have to fill one of these: http://minuszerodegrees.net/5162/cards/5162_cards.htm#emea
Your IBM only goes up to 4MB? and what is the FSB of the system? If 20MHz or more, you could get 40ns DRAM to read/write within 1 clock cycle... using 60ns would take 2 clock cycles.
I thought about these ISA bus SIMM extenders before... would they limited to an ISA bus clock divider down to something like 4MHz or would they be remain at the system clock i.e. 16MHz / 20MHz?
Reply 281 of 287, by The Serpent Rider
Aren't any memory with 70ns or less is way out of specs for 386 and should work too?
Reply 282 of 287, by The Serpent Rider
Soo... acquired the best (tm) motherboard for 386DX I could find. VLB, 256kb Cache, Cyrix 486 support, etc. Well, almost: sockets for 386 CPU/FPU are not soldered, but apparently my version of Dataexpert EXP4349 board is lacking only in that department. All jumpers from online manuals appears to be present. So all I need to do is to add those sockets, right? Or I'm missing something?
1.08 MiB
688.99 KiB
844.62 KiB
Also I'm confused with 3.3v option for CPU without voltage regulator present on the board (jumpers 50, 51, 52).
Reply 283 of 287, by feipoa
It probably doesn't have a 3.3 V option without the voltage regulator, so set the jumpers for 5 V.
In all liklihood, soldering in the 386 and FPU sockets will allow you to use 386 CPUs. Aside from the missing voltage regulator, are there many missing components?
Reply 284 of 287, by The Serpent Rider
I am not sure where voltage regulator could be installed on this board.
323.49 KiB
Maybe here vertically?
That's what I want to know from the other owners. Jumpers are safe, components seems to be safe too, judging by this pics: https://imgur.com/a/sZPMB
Reply 285 of 287, by feipoa
Yes, that is the spot which I would guess the voltage regulator IC goes. What I find further interesting about those photos on imgur is the sticker "This PGA socket is intended for TI486SXL Microprocessor only". I've never seen such a sticker on a motherboard. I'm guessing that certain jumpers were soldered on for the SXL pinout, which has some minor differences with the i486SX pinout, yet, an SX CPU is installed.
Reply 286 of 287, by God Of Gaming
Took a quick look for any local 386dx40 mobo listings, and found two:
This unknown model with Opti chipset and soldered cpu (no big deal, its dx40)
And this ROBOTECH GMB-386UN with a... Toshiba chipset it says?
Is one of these two any good and worth adding to my collection?
1999 Dream PC project | DirectX 8 PC project | 2003 Dream PC project
Reply 287 of 287, by dj_pirtu
Got myself a MG-38606 REV 2 motherboard with UMC48x. Flashed MR BIOS and got lots of BIOS settings to tinker with.
There's 486DLC-33 and I've been overclocking it to 40, 45 and 50MHZ.
Motherboard takes FSB to 50MHz but after few minutes it'll start crashing. If I put 120mm fan to blow on to motherboard it works. Still need to hunt that chip which will need that kind of cooling among CPU.
I have 16MB 60ns RAM and 1WS is needed 45MHz upwards. 256KB cache works with 0WS.
