First post, by wbahnassi
Hi, I'm looking for your help identifying this 286 motherboard I recently found. Hoping I can find the manuals for it to know what are its jumpers and the range of processor speeds it accepts. It's currently missing the CPU, but I ordered a Harris 16MHz 286 CPU as it seems this mobo is configured for that CPU speed.
I'm hoping I could find a way to reroute the PC Speaker to an actual speaker on the case instead of the buzzer on this mobo, plus I wonder where are its connectors for HDD, Turbo and Reset... if at all...
Thanks in advance!
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 1 of 14, by retardware
Maybe it could be worth looking closely at the small chip near the buzzer?
It is slower than a 286-16 😀
Edit:
Near to the chip and the buzzer are also two connectors, 34 and 40 pin.
So there is only left to make sure that the PSU connector actually is P8/P9 compatible, so that the self-destruct function does not get triggered.
Reply 2 of 14, by Deunan
wbahnassi wrote on 2021-10-01, 15:32:
Nope, that is a 386 board. You have 16MHz Intel 386SX on it, you even took a photo of it. That socket is for 387SX NPU.
Reply 4 of 14, by SDumas
Philips P3345 ?
Reply 6 of 14, by wbahnassi
Ok a few more pics around the buzzer and the P8/P9 power connector:
I don't see where it says Philips P3345, but looks like Mr.Slug's link is indeed showing the right schematics. I wasn't familiar with this CPU package type before. Nice.
Now, looking at the manual linked in Mr.Slug's link, it doesn't seem to include neither an HDD led connector, nor a Turbo button connector, right? I thought all mobos from this era had a Turbo switch.
BTW, the previous owner said the machine that was using this board was turning on but not showing anything on the screen. I haven't tried it yet, but I hope it was something stupid that was preventing it from working.
Reply 7 of 14, by mR_Slug
DEC was a business orientated manufacture and turbo buttons probably weren't high priority. Sometimes there is a key combination to switch speeds. Shift-ctrl-+ I think, perhaps someone else can remember. Dunno about the HDD light though.
Can we use your image on our site? Ultimate Hardware 19 now has close to 9000 motherboards.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 8 of 14, by wbahnassi
mR_Slug wrote on 2021-10-02, 19:11:
Sure no problem. I can try to take better or detailed pics if needed also.
Reply 9 of 14, by wbahnassi
Hooked it up last night and started to hear sweet music to my ears: beeps and blips 😀
At first I didn't get any picture (just like previous owner said). I hooked it up on a CRT he gave me, which I tested on a different machine and it lit up and gave a beautiful picture. However, on this 386SX it failed to show any picture. It's hooked up to an ATI Wonder 16 VGA card, so I tried a modern LCD monitor and I got picture.. 🤷‍♂️
For the record, to enter the BIOS setup utility on this mobo keep pressing Ctrl+Alt+Insert at different times during the POST screen. POST doesn't show any help messages on how to enter the BIOS, so I thought this might come in handy for any Philips 386SX mobo owners to come.
Reply 11 of 14, by dewitman
The speed can be changed in the BIOS
The HDD light is directly connected to the HDD
Reply 12 of 14, by wbahnassi
Coming again for this. Anyone knows what "burn in mode" switch is for on this motherboard:
https://stason.org/TULARC/pc/motherboards/D/D … SX-CE-P334.html
Cheers!
Reply 14 of 14, by wbahnassi
Some more digging. Apparently this motherboard was used in the Magnavox Headstart 500
https://wiki.preterhuman.net/Magnavox_HeadStart_500
I found a manual convering several similar Magnavox models, and it revealed a secret key combination to toggle Turbo mode on/off. It beeps on toggle. You press Alt+LeftShift+RightShift.
Manual: https://drive.google.com/file/d/1Xqjl7oJK3_lm … iew?usp=sharing
POST codes can be found here (look for Magnavox Philips):
https://mrbios.com/techsupport/award/postcodes.htm
Funny it is mentioned this motherboard was made in Montreal, which is where I got it from as well 😀
Setup disks:
https://vetusware.com/download/Andy%20Samuels … 01991/?id=10018
I couldn't find exactly what CMOS battery it used. It is visible in the photo above. Anyone has experience what type of battery/voltage it could be? I'm assuming it is not rechargeable...
