First post, by keropi
Hiya!
can anyone identify this 8088 motherboard? I tried searching for "SUPER 10-B" but I did not find anything useful...
any hints will be appreciated, thanks!
Reply 2 of 21, by keropi
I am not worried about acid damage , I'll just spend some time and fix it. I am more worried from lack of documentation 😀
Reply 4 of 21, by keropi
Yes I have found the B1 bios site, what would be more interesting is the jumper block setting. I have also found some B1 pics online, main difference is a variable cap on the xtal1 position, B has a fixed one
Reply 6 of 21, by rein_ein
Tried search in TH99 archive without luck,so best i found is topic about bios,the good that it was bumped after seven years,last time in 2015 and there at least 2 owners of this mobo on the forum
http://www.phantom.sannata.ru/forum/index.php … um_view&o=&st=0
Reply 7 of 21, by keropi
@kanecvr
the pictured mobo has full 640kb , maybe the extra sockets where used with lower capacity ram ICs
@rein_ein
thanks for that, checking it but I don't recognize any nicks from here - what am I missing? 😁
as per the Russian thread the mobo might be similar to this: http://www.uncreativelabs.de/th99/m/U-Z/33682.htm
Reply 9 of 21, by keropi
ah, no problem rein_ein - still I got some leads 😀
are they still searching for the BIOS? Or google translate is way off?
Reply 11 of 21, by carlostex
Your board seems to be a revised, more modern version of the one on the link. In fact it seems to accept 44256 RAM chips. Also on your board JP5 is on a different position, and headers are rearranged compared to the older version. For your board, JP3 is for Turbo Switch and LED, JP4 for Reset and JP5 for Power LED and Speaker.
DIP switches you can follow the info on that page. Should be pretty much the same.
Reply 12 of 21, by Imperious
I have the board pictured below, obviously a newer one than Yours based on the F revision.
    649.23 KiB
Reply 14 of 21, by Imperious
This is all I could find
http://stason.org/TULARC/pc/motherboards/U/UN … -MAINBOARD.html
Reply 15 of 21, by mtsiakiris
Hi, is anyone still interested?
I own this motherboard and I am trying to bring this back in life. There is a manual too, I can share more pics, just pm me.
Thanx!
    191.99 KiB
    1.55 MiB
Reply 16 of 21, by Doornkaat
mtsiakiris wrote on 2023-01-08, 11:51:
Thanx!
I think it would be best if you could scan the whole manual and upload it in The Retro Web project - a better stason.org/TH99 alternative
Thank you for your initiative! 😃👍
(Also sending you a pn as you requested.)
Reply 17 of 21, by MMaximus
Thanx!
Does yours work at 4.77Mhz speed? I used to own a similar board but never found the setting to disable the 10Mhz turbo mode.
Hard Disk Sounds
Reply 18 of 21, by mtsiakiris
MMaximus wrote on 2023-01-09, 19:22:
Yes, it works on both modes, it has a special pin that is connected to push-on / push-off button in front of the case.
Wait till I upload the full manual and may be that lead you to something similar in yours.
But, depending the bios chip, management chip and oscillator crystals on your board, it might be impossible for you to run on 4.77.
Reply 19 of 21, by mtsiakiris
Doornkaat wrote on 2023-01-08, 12:41:
I think it would be best if you could scan the whole manual and upload it in The Retro Web project - a better stason.org/TH99 al […]
Thanx!
Hi again, trying to upload the manual in PDF, but exceeds limit of 5MB. So, sharing a public url here: https://drive.google.com/file/d/1_vYxBMdSYJ5_ … ?usp=share_link
