First post, by red-ray
red-ray
Offline
- l33t
I am pondering getting a https://www.amazon.co.uk/ORICO-Enclosure-Comp … y/dp/B0B2781662 but before I do would like to know which USB 3.2 to PCIe/NVMe bridge chip it uses. I expect it will be either ASMedia, JMicron or Realtek as AFAIK these are the only ones that exist, I have looked on-line to no avail. If you have one then my SIV utility should report this when it's running in USB 3.2 mode, but not USB/Thunderbolt 4 mode as a USB bridge chip is not needed/used.
The latest SIV beta should also report the SMART information for USB attached NVMe drives.
