Re-making worst mouse ever
First post, by AmbraSprintaII
Hi all!
My first PC was an Ambra Sprinta II, a machine I still own. I have a thread about it here: Ambra Sprinta II
It originally came with a mouse that has been described as 'a torture device'. And even by 90's standards, the design is certainly questionable.
Here are some images from wikimedia for reference.
Well I wanted to "recreate" this abomination, as I've since lost mine. I'm trying to learn a bit of FreeCAD, but I'm admittedly pretty bad at it. Trying to measure off the pics from wikimedia, I ended up with something like this.
The attachment freecad_model.png is no longer available
I used the guts from an old logitech mouse. It was a USB one, but supported PS/2, so I just rewired it with a PS/2 cable.
The attachment transplant.jpg is no longer available
I found a spray paint primer, that had a similar color. Not a perfect match, but good enough to tickle my nostalgia.
The attachment top.jpg is no longer available
The attachment bottom.jpg is no longer available
And here it is, paired with the machine. And I'm pleased it actually works really well.
The attachment paired.jpg is no longer available
I know it is sub-par work in pretty much every step of the build. But it's at least a project that I got somewhat finished.
I might revisit it later, and to a better job in sanding and painting, maybe print a logo and make an acrylic window that is still missing.
Thanks for reading, and have a nice day fellow retro-pc enthusiasts!
Reply 1 of 21, by TrashPanda
WTF is that mouse...???? (Not your printed one)
Oh god just put it back in its box before it breeds.
Reply 2 of 21, by devius
At first I thought it didn’t look as bad you described it, but then noticed where the buttons were.
Nice job with the recreation though! With the logo dome sticker it should look pretty good.
Reply 3 of 21, by AmbraSprintaII
TrashPanda: I don't think you need to worry. Even with my half-assed resurrection attempt, they are very much extinct.
devius: Yeah, it's not great. But, it is actually not as bad as it looks. You just kind of rest your fingers on the top edge of the buttons, and it click pretty much like a 'normal' mouse. You don't need to 'make a claw' and click using the flat part of the buttons. Still though... Weird and bad design, but it's what I grew up with and it certainly made an impression 😀 Thanks for the encouragement!
Reply 4 of 21, by TrashPanda
AmbraSprintaII wrote on 2023-03-02, 09:38:
I will say I do like the shiny new version ...wonder what it would look like in clear plastic ...with rainbow vomit leds in it.
Reply 5 of 21, by AmbraSprintaII
ThrashPanda: Thanks! Ugh... I felt bad enough about using an optical mouse 😀
Reply 6 of 21, by TrashPanda
AmbraSprintaII wrote on 2023-03-02, 10:53:
I think it being in clear colored plastic would be a great fit for 2000 era colored acrylic cases ..you know the ones with the tacky clear colored plastic on them...the kind you can see the literal metal case under it.
Reply 7 of 21, by AmbraSprintaII
TrashPanda: Yeah, I know the ones, the iMac look-a-likes. Well, sure, but there has to be a better designs out there to work off... The only reason for this is to replicate my original setup. To have a mouse somewhat like what this computer originally had... Coming to think of it. The original iMac mouse was pretty damn horrid aswell...
Reply 8 of 21, by TrashPanda
AmbraSprintaII wrote on 2023-03-02, 13:34:
TrashPanda: Yeah, I know the ones, the iMac look-a-likes. Well, sure, but there has to be a better designs out there to work off […]
Your mouse actually looks significantly better than the original, The shiny look works well for it.
Reply 9 of 21, by Doornkaat
TIL Stockholm Syndrome is a thing in computing as well.😲
Good job, AmbraSprintall!😄👌
Reply 10 of 21, by Deunan
The original Genius 3-button mouse was a torture device. At least this one is round, I still remember palm pain from playing mouse-driven adventure games back when I had the Genius.
Reply 11 of 21, by AmbraSprintaII
TrashPanda: Well, it's just a layer of clear coat to protect the paint a bit. Not really all that intentional tbh, but thanks!
Doornkaat: It sure is. Thanks 😀
Deunan: I might have exaggerated with the 'worst ever'. I'm sure there are worse. I looked it up and I'd agree that the Genius mouse sure does not look very ergonomic.
Reply 12 of 21, by dionb
Deunan wrote on 2023-03-02, 13:47:
It was hardly great, but no, there were far, far worse mice.
After four years of inflicting RSI on myself with the IBM PS/2 mouse I saved up pocket money for a few months to buy that Genius mouse, and it was as close to bliss as a pointing device could get my teenage self in 1992.
Even now I have one lying around as a known-good serial test device. Not something to actually use for any extended period of time, but perfectly serviceable to see if everything is wired up correctly.
Reply 13 of 21, by Deunan
That Genius worked well, I'll give them that. And it had a nice, heavy ball that was easy to clean with water and soap (that's the only thing I have left of it, stored in some box).
Reply 14 of 21, by rasz_pl
This had to be a desirable mouse shape, even russians cloned it https://svoymaster.kz/%D0%BA%D0%BE%D0%BC%D0%B … B5%D1%80%D1%8B/
and pictured on the wikipedia: https://ru.wikipedia.org/wiki/%D0%91%D0 ... 9A-0010.01
Reply 15 of 21, by BitWrangler
I have a monstrosity somewhere similar in footprint, not sure it's quite so domed, like a puck stuck to a matchbox, buttons are on top more. I wanna say it was by someone who should have known better like Logitech, not sure though.
Reply 17 of 21, by AmbraSprintaII
devius wrote on 2023-03-04, 14:55:
But the buttons are on the right place on that one, so not exactly the same.
But it makes up for it by using a ribbon cable 😀
Interesting find, thank you rasz_pl for sharing!
Reply 18 of 21, by brassicGamer
Yo, this is SO COOL. An Ambra Sprinta was my first computer growing up and I actually had no problem with the mouse. Sadly my dad threw it all away after I moved out, but last year I found one on eBay for hardly any money. Sadly it had no peripherals, but did have the monitor. Can you share na STL or something of your design? I would love to have a go at making one as I have a 3D printer.
Reply 19 of 21, by luckybob
ALSO: https://www.youtube.com/watch?v=u4RkkjiYu0k
i'm happy they didnt blow up the mouse when they plugged it directly into the serial port on that PC.
