Reply 20 of 82, by rasz_pl
goes crazy at [3D 1.Initialise keyboard] post code
responsible chip lower right corner https://pdf1.alldatasheet.com/datasheet-pdf/v … ND/W83627G.html
more cards more stable might just mean plugging one of the cards flexed the board slightly - try pushing this chip down with finger and then start computer (while pushing), or get a loupe + needle and go over every single pin
another option is more cards = more load = cleaner power, would need scope to check
does this same ps2 keyboard still work in another computer?
