First post, by Soap
Basically I've acquired this old Dell 486 (Model 466/LE).
Upon booting I get the HDD failed message, I press F1 to continue and it boots no problem and runs without issue.
What could be causing this issue? I just flashed the bios from A01 to A08 and I get the issue still.
Cheers in advance.
Reply 1 of 9, by BitWrangler
Sometimes ageing drives don't come up to speed fast enough to beat the check. That can also be a PSU ageing issue, it doesn't quite deliver enough at the power on surge to get everything going.
Reply 2 of 9, by jakethompson1
Might there be a missing second hard drive enabled in the BIOS setup
Reply 3 of 9, by rasz_pl
>Medalist 2122 (ST32122A) provides the following key features: Low power consumption; Quiet operation; Support for S.M.A.R.T. drive monitoring
maybe bios supports SMART too and drive has errors logged/is on a way out
Reply 4 of 9, by Boohyaka
that looks to me like you have a secondary (non-connected) disk configured in BIOS
Reply 5 of 9, by Soap
Boohyaka wrote on 2023-03-09, 19:13:
You sir are an absolute legend.
I had disk 1 in the BIOS set to Auto, nothing is connected so I just figured with it being on Auto it would be able to tell, I set to disable and problem is gone.
No idea why I never thought of that, had a complete brain fart that time.
Cheers
Reply 6 of 9, by Boohyaka
Allright, glad it's fixed! Just noticed now jakethompson1 already had the right answer a couple of minutes before me though 😁
Reply 7 of 9, by Horun
Nice ! Never seen a white wrapped HD before, seen many black wrapped ones. Nice pictures. Glad you got it working.
Reply 8 of 9, by Soap
jakethompson1 wrote on 2023-03-09, 19:10:
It certainly was, I had a bit of a brain fart and missed that.
Many thanks
Reply 9 of 9, by Soap
Horun wrote on 2023-03-10, 00:33:
I'll get some better pics when reassembled and fully set up, and thanks.
