First post, by happyguy44
ok i try installing this into the dos bot but everytime it just seems to do nothing and freezes at the spot were it says it needs to do a scan disk. Is there any way to get past this? i apologize if this sounds stupid and thanks in advance. ๐Ÿ˜’ ๐Ÿ˜Š ๐Ÿ˜• ๐Ÿ˜Ž ๐Ÿ˜ต ๐Ÿ˜ข ๐Ÿ˜ ๐Ÿ˜ˆ ๐Ÿ˜ฒ ๐Ÿ˜€ ๐Ÿ˜˜ ๐Ÿคฃ ๐Ÿ˜  ๐Ÿ˜’ ๐Ÿค‘ ๐Ÿ˜ฆ ๐Ÿ™ ๐Ÿ˜– ๐Ÿค ๐Ÿ˜ณ ๐Ÿ™„ ๐Ÿ˜ ๐Ÿ˜ฎ ๐Ÿ˜œ ๐Ÿ˜ ๐Ÿ˜‰ ๐Ÿ˜…
Reply 2 of 2, by butterfly
DosFreak wrote:
Windows 98 doesn't work in DosBox. Only Windows 95.
That's correct, it doesn't work. You can install it completely though.
The only way I succeeded having it working is changing the shell from explorer.exe to progman.exe
