First post, by Riikcakirds
Is there a dos program that can reduce the amount of conventional memory/ upper memory available.
Like loadfix in dosbox, you can type loadfix 40 and it will use up 40KB memory and reduce your conventional memory by that amount. Then you have the option to remove it later.
I need to load an old recovery program (Allmicro) in real dos and loadfix (which just allocates and uses up the first 64KB) doesn't help.
The program won't run with memory above 500KB.
