First post, by geiger9
- Newbie
I'm having a lot of trouble with this Samsung 386s/20N and using a compact flash adapter with it.
I have used the same:
- floppy drive
- compact flash adapter
- 256MB compact flash card
- floppy drive cable
- IDE cable
- DOS install disks
in an early Pentium machine and I could install DOS 6.22 just fine onto my CF card.
However, when I connect this same equipment to this Samsung 386s/20N and try it, DOS fails at 99% every time saying there was an error writing to C.
I can install DOS to a hard drive on this machine without a problem.
You may be thinking - why not just install DOS on the other machine and then hook it up to your Samsung? I tried that and after the machine POSTs it gives the error "missing operating system".
I found the CHS values for my CF card using another computer that auto detected the values. I entered these in the BIOS on the Samsung.
When I look at the motherboard there is a set of DIP switches located near the IDE host adapter. I'm wondering could these switches do something that would affect how an IDE device works. Can anyone here tell by looking at the traces on the top of the motherboard if this is the case? Unfortunately there is no documentation for this motherboard online. I guess if these DIP switches are not the answer, then I would need to buy new adapters (ones that are not the design you find on Ali Express) and see if those work. I have several of these machines and I have so many CF adapters so that's going to be a last resort. Hoping someone can help 🙁
Edit: I did try and install FreeDOS on the Samsung just to see what would happen. I ran into an error again with C drive as seen in the picture below:
