First post, by BadManiac
I'm running in Windows XP Pro SP2, Asus nForce 590 AM2 mobo with PCI Express x16, AMD Sempron 3000+, 2GB DDR2-800 dc, and a 256MB Geforece 7600GT.
I've tried the latest stable 0.71, as of this post, and ykhwong's latest 0.71 (08/06/2007) CVS build.
Direct3D with "none" in the pixelshader field silently CTD's when going to full screen, no error message, Dosbox completely shuts down.
D3D with any pixelshader FX file selected crashes with a generic error message "has encountered a problem and must shut down"
And both OpenGL and OpenGLHQ run extremely slow, regadless how simlpe the game is, it run at around 1-2 FPS (as far as I can tell).
I know my system is capable, because when I use "surface" for output, and scaler=hq2x or normal2x DOSBox runs flawlessly. And I can play Oblivion (d3d) on max settings, as well as quake4(GL) on high perfectly, so there' no problem with my graphics card, or drivers.
I was hoping to get the scaling for "free" in GL or d3d, freeing up some more cycles of my poor Sempron for the heavier games, like Daggerfall or Commanche 2-3, so they'd run a tad more smoothly.
Any ideas?
Reply 1 of 16, by Targaff
ykhwong wrote:
There will be little support for the unofficial CVS builds.
That said, I continue to have this problem as well, despite the fixes in the latest build, with a "failed to reset device" error on exit. I note the English board on Daum Cafe seems to no longer be there, and I hope it's not because of people haranguing him about it, since I know it was mentioned a lot after the previous build.
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Reply 3 of 16, by Targaff
23.06.07 worked fine for me with an identical config. I do get "SDL:D3D:Cannot Lock Texture, fallback to compatible mode" whenever I start either build, though.
Reply 5 of 16, by ykhwong
That is the incompatibility with menu patch if dosbox crashes with fullscreen+direct3d.
Set output to direct3d in configfile and use "-nogui -fullscreen" for dosbox.exe.
Though it could be just a temporary fix, it should work. I am trying to make it work, but no success.
Reply 6 of 16, by gulikoza
I'm not familiar with the gui code, but can't you disable gui for fullscreen? 😀
@Targaff: that's just a fix for Windows 2000. You do have w2k, right? 😀 It's nothing to worry about...
http://www.si-gamer.net/gulikoza
Reply 7 of 16, by ykhwong
Disabling GUI for fullscreen did not work. Using sdl_windowid for menu bar patch, it is programed: when going to fullscreen, sdl_windowid is unset while the sdl_windowid is set when going back to window.
You can find some "winid_chk();" in sdlmain.cpp. (see menu patch thread in the beta tesing forum) I am still trying to find another way... 😀
Reply 8 of 16, by Targaff
Thanks for the switches, ykhwong, they worked fine - actually you can ALT-ENTER to fullscreen if you don't use -fullscreen to start (though I do still get a crash if you try the other direction - "Exit to error: could not set video mode 640x400-32: Couldn't get user specified window"; dunno if that's any help in finding where the problem lies?)
gulikoza: yeah, w2k. I figured since I got it regardless of the build that it wasn't an issue, I just didn't understand it 😉
Edit: actually I seem to get that error coming out of fullscreen regardless of what output I'm using...
Reply 9 of 16, by ykhwong
Fixed.
Reply 10 of 16, by Targaff
Many thanks!
Reply 11 of 16, by BadManiac
Been awol for a bit, come back to update on this and it's already FIXED! Thank you all for helping, especially ykhwong for a quick fixed build. Will test it after work tonight and give feedback here.
Reply 12 of 16, by BadManiac
Tested Direct3D with the new build. Works flawlessly now, can Alt+Enter in and out as I want, even switch shaders on the fly with the menu. Thank you for that.
However I saw virtually no improvement over using output=surface and HQ2X scaler. Is this normal? I would have assmued that offloading the scaling operation to the GPU would free up a good few CPU cycles to run the actual game?
I tried direct3d scaler normal2x with various shaders, and it didn't make any difference in performance from surface and hq2x. 😒
Reply 13 of 16, by gulikoza
Depends on the graphic intensity of the game (how many times it refreshes the screen...)
Also be sure not to use normal2x with shaders. Normal2x implies a software 2x stretch before the pixelshaders...
Reply 14 of 16, by BadManiac
Is there a way to use direct3d to scale in windowed mode then? a 320x200 window is rather small, and hard to see. aDn some things are handy to play windowed.
Reply 15 of 16, by gulikoza
windowresolution= 😀
In my builds, I also have a hardware2x scaler, which is the same as normal2x, but uses hardware stretching where available...
Reply 16 of 16, by BadManiac
Ok... Something is definitely fishy. ykhwong's new build that I played an hours worth of Ultima Underworld on earlier, now has the exact same problem as before. Crashes when going to fullscreen, direct3d just doesn't work at all. get failed to reset device errors several times in the output console window.
Not touched the conf file, not done anything strange to my PC at all. It just stopped.
[edit]
It seems to "work" intermittently, once every few times it works and I can go to full screen. Very rarale does it allow me to go back to windowed without crashing tho.
By "work" I mean it does nothing at all.
When I use ouput surface, original resolutions and scaler hq2x I get nice upscaling as you'd expect.
When I chose direct3d, hq2x.fx shader, and no scaler, it doesn't matter if I use original resolution or set a specific one, I get the original jagged edge low resolution, no difference at all. Very odd.
