Descent
First post, by themooingcow
okay i made my directory c: for dosbox and im trying to do
cd descent and it wonlt let me change it so that i can do descent.exe to play descent can someone help??? and if there is an easier way to play on dosbox can u tell me please thx
Reply 1 of 12, by wd
Rank DOSBox Author
DOSBox Author
What about telling exactly where the directories are and how you mount them?
Did you read through the guides threads?
Easier way: search for frontends.
Reply 2 of 12, by themooingcow
what are frontends
and yah i saved descent to old games 2 in the c directory and i mounted that then when i go and try to do
cd descent
iy says descent cant be changed
Reply 3 of 12, by wd
Rank DOSBox Author
DOSBox Author
forum.search.frontend()
Post the exact commands you used for mounting.
Reply 4 of 12, by themooingcow
like this
frontend C C:\ old games 2
Reply 5 of 12, by wd
Rank DOSBox Author
DOSBox Author
Did you type "c:" after mounting?
Otherwise ??? and post a screenshot of what you REALLY did.
Reply 6 of 12, by themooingcow
🤣 umm how do u post a screenshot
i just installed dos box like a few days ago
heres what i did
Z:\>mount C C:\ old games 2
(in red) Mounting C:\ is NOT recomended. please mount a (sub)directory next time.
Z:\>C:
C:\> cd descent
unable to change descent
thats exactly what i did
Reply 7 of 12, by themooingcow
Drive C is mounted as local directory C:\
Z:\>C:
C:\> cd descent
oh yah i forgot to add what it said after
Reply 8 of 12, by wd
Rank DOSBox Author
DOSBox Author
type this:
mount C "C:\old games 2"
Care of spaces.
Reply 9 of 12, by themooingcow
ok desccent is in the directory know but how do i play it???
oh and btw thx for helping
Reply 10 of 12, by themooingcow
ok i figured out how to play nvm so i just do that for all the other games???
Reply 11 of 12, by wd
Rank DOSBox Author
DOSBox Author
No, see the [autoexec] section of dosbox.conf
All commands entered there will be executed on startup,
so place your "mount ..." and "c:" things there.
Reply 12 of 12, by themooingcow
oh cool thx
