First post, by yukinoshita
Hey,guys.I received an Omni book 600ct yesterday without a hard drive.I bought a 2gb cf card to IDE and try to install dos 6.22 on it(By using virtual machine)
But no luck.When I boot it,it says disk I/O error.
Then I use winimage and flash a win95 copy which was for libretto 70 and It also says Disk I/O error.
What should I do to install system correctly?
All I have is a cf card to IDE hard drive.No cd-rom,no floppy and no dock…I am looking for your help …
The attachment 5797700E-4F35-4CE2-9048-DFFCA7FEBD96.jpeg is no longer available
The attachment FAB51540-FB4A-464F-9626-7D9D583FC136.jpeg is no longer available
My collections:TP750c TP A31 Ominibook XE3 and 600Ct.Toshiba Libretto 60 ,50M,satellite 320cdt.Vaio P47 and C1XF C1VS.A little jornada 688..
Reply 1 of 14, by paradigital
Does the “HDD” need setting up in the BIOS with the correct CHS?
Reply 2 of 14, by yukinoshita
paradigital wrote on 2023-03-31, 16:22:
At first I even don't know how to enter bios for this cute one.But then I realize it is impossible to get into bios for 600ct because of HP’s restrictions.(From https://marc.info/?l=freebsd-mobile&m=103032938519633&w=2)
Reply 3 of 14, by yukinoshita
Waiting for your guys …Anyone knows how to install system correctly?
Reply 4 of 14, by PC Hoarder Patrol
yukinoshita wrote on 2023-03-31, 17:48:
May be related to partition setup - check this old thread Reinstalling W95 on Omnibook 600CT
HP did provide an OmniBook 600C and 600CT BIOS and Driver Update for Windows 95, which you can still download here https://driverscollection.com/?file_cid=44758 … 73e352cd4c4303d though not sure this expanded utility package will run from anything other than a floppy!
Reply 5 of 14, by bartonxp
Here's an Omnibook archive, lots of documentation, not sure if anything's useful to you: http://omnibooks.info/archive/
Reply 6 of 14, by yukinoshita
PC Hoarder Patrol wrote on 2023-03-31, 20:23:
Thanks,may be I can write this in USB-ZiP mode to my cf card.I will have a try.
Reply 7 of 14, by yukinoshita
bartonxp wrote on 2023-03-31, 20:44:
Quite useful and I found the floppy image. Try to get it work on the cf card.
Reply 8 of 14, by yukinoshita
So I guess it was a partition problem and I found this https://hpmuseum.org/forum/thread-8774-post-77196.html
Reply 10 of 14, by yukinoshita
Disruptor wrote on 2023-04-01, 06:33:
yukinoshita wrote on 2023-04-01, 04:57:
On what system have you created the partition?
Was it from a Windows Vista, 7, 8, 8.1, 10 or 11?
A virtual machine running dos6.22 by using fdisk.
Reply 11 of 14, by yukinoshita
Next step I will try to create the partition on my TP750c.I will use cf card to pcmcia then connect it to my TP which is running dos6.22. Then insert the diskette mentioned in Omnibook.info.I will try my best to get the little Omnibook back to life.
Good luck to me. I will update here.
Reply 12 of 14, by yukinoshita
I noticed they use OBfdisk rather than fdisk.
Reply 13 of 14, by yukinoshita
The attachment 132777F8-CBD6-405D-96C7-7F34106A4C13.jpeg is no longer available
Update:No IO errors now but it stuck here…any advice?(USB- HDDmethod and USB-ZIP method get the same result..)
Reply 14 of 14, by yukinoshita
Finally I got it.Use the images in the Omnibook.info and then go to the virtual machine to load the floppy diskettes then recover it.When it was done,plug the cf to cf to pcmcia card.Insert it into TP750C,type sys D:.Then it can boot.
