Best isa gpu? [solved]
Reply 60 of 79, by red-ray
PC-Engineer wrote on 2023-04-02, 07:02:
HighColor with 16Bit up to 1280x1024.
Thank you for the links and it's 1280 x 1024 x 16-bit colour that I would really like, there look to be NT4.00/3.51 drivers @ https://oemdrivers.com/graphics-s3-p86c928.
Now I need to find one of those cards which I suspect will be tricky
Reply 61 of 79, by red-ray
kixs wrote on 2023-04-01, 10:02:
Actually I get 17MB/s on VLB and 18MB/s on PCI bus. It's definitely not an ISA bus 😉
With hindsight I should have RTFM, I now have and from SIV 5.70 Beta-04 the bus type will be reported 😀
file.php?id=161359
file.php?id=161362
Reply 62 of 79, by Grzyb
Consider replacing "VLB" with just "Local Bus" - it's impossible to tell apart VESA vs. Opti vs. onboard in software.
Reply 63 of 79, by red-ray
Grzyb wrote on 2023-04-02, 13:45:
I don't understand what this means, Local Bus could mean either of VESA Local Bus or PCI Local Bus , SIV is reporting the GPU not the motherboard chipset.
The GPU chipset datasheet specifies VESA Local Bus for the mode the GPU is using so it's sensible for software to report this for the GPU.
Reply 64 of 79, by Grzyb
red-ray wrote on 2023-04-02, 14:02:
Yes, one datasheet refers to that as "VESA local bus", but the other as "386DX/486 local bus".
The latter is more precise, because it doesn't imply that the VESA slot is used.
386/486 local bus can be used via VESA slot, Opti slot, maybe some other slot, or onboard = no slot at all.
Reply 65 of 79, by red-ray
Grzyb wrote on 2023-04-02, 14:18:
Earlier posts make it clear the 86C764 is on the motherboard and not in a VESA slot at all, so why are you now talking about VESA slots?
For a 86C764 GPU to be operating in VESA Local Bus mode clearly it does not need to be in a VESA slot.
Further the SIV screen shot shows it's a 86C764 and the 86C764 datasheet says VESA Local Bus so what SIV is reporting is 100% correct.
Basically what you keep posting makes no sense at all.
Reply 66 of 79, by pentiumspeed
There is no such as local PCI. The "local" meaning is nonsense.
VESA local bus is correct in long, VLB in short and is designed for 486 and was designed by VESA committee back then.
Please stick to industry standards terms.
Cheers,
Great Northern aka Canada.
Reply 67 of 79, by red-ray
pentiumspeed wrote on 2023-04-02, 14:57:
There is no such as local PCI. The "local" meaning is nonsense. […]
I am quoting what is in the S3 datasheet and clearly you need to tell S3 to correct their 86C764 datasheet.
Please don't shoot the messenger!
Further I feel you are incorrect and need to get your facts right before you post
Reply 68 of 79, by Grzyb
Basically, 386DX and 486 CPUs have 32-bit external bus, referred to as 386DX/486 local bus.
That bus can be used by onboard devices, or by cards using slots.
There are at least two slot standards for that:
- VESA Local Bus
- Opti Local Bus
As they are just slot standards, it's impossible to distinguish between them in software.
Am I wrong somewhere?
Reply 69 of 79, by rasz_pl
pre vesa https://www.freepatentsonline.com/5426739.pdf Re: Pre-VESA Proprietary 32-bit Local Buses?
Reply 70 of 79, by red-ray
Grzyb wrote on 2023-04-02, 15:07:
Yes, it's the MODE the GPU is operating in. It can be in PCI mode or VLB mode and as to what is connected to does not matter.
Yet again on the [GPU Information] panel SIV is reporting the GPU mode and nothing more. It is not saying anything about the motherboard chipset.
Were SIV to report what you are talking about it would be on the Menu->Hardware->Chipset->Chipset MCH panel as it's nothing to do with the GPU mode.
Reply 71 of 79, by Grzyb
OK, the term VLB is good enough, you can use it if you wish.
Nevertheless, S3 isn't consistent in using that term.
Reply 72 of 79, by red-ray
Grzyb wrote on 2023-04-02, 15:43:
Yes, I posted sections from two datasheets partly to show this and also to show the 86C924 had ISA + ESIA modes.
We will have to live with inconsistent names in 20+ year old data sheets, I am far more interested in getting S3 86Cnnn datasheets that are not scans so I could search them than worrying about this.
Reply 73 of 79, by BitWrangler
red-ray wrote on 2023-04-02, 14:46:
[For a 86C764 GPU to be operating in VESA Local Bus mode clearly it does not need to be in a VESA slot.
That is correct, VLB is basically direct to 486 with fluff and frills, just wiring it to CPU directly with a local bus that does not have the Vesa fluff and frills, will still look like VLB, there's not a way to say "Hey look they didn't install a socket with all the power and the pins in the right places"
Reply 74 of 79, by weedeewee
Cheers,
Is this what you're referring to as industry standards ?
PCI Local Bus Specification Revision 2.3 March 29, 2002 […]
PCI Local Bus
Specification
Revision 2.3
March 29, 2002
http://www.cisl.columbia.edu/courses/spring-2 … outs/pci_23.pdf
Do not ask Why !
Reply 75 of 79, by rasz_pl
red-ray wrote on 2023-04-02, 15:23:
no
there is no such thing as VLB mode. VLB describes just dropping piece of electronics on raw CPU memory/data bus. Same Trio32/64 chips were used in Amiga graphic cards https://bigbookofamigahardware.com/bboah/product.aspx?id=463 in exact same way, chip connected to Zorro memory/data bus. I dont have to mention Amiga never had VLB 😜 Even chip manufacturers can make mistakes in their own documentation, or fill it with marketing jargon.
Reply 76 of 79, by red-ray
rasz_pl wrote on 2023-04-02, 17:30:
I never said there was, I said the "86C764 was operating in VLB mode" which is the situation.
Reply 77 of 79, by rasz_pl
would you also call Voodoo3 3000 AGP plugged into AGP port as operating in "AGP mode"? 😀
Reply 78 of 79, by cyclone3d
red-ray wrote on 2023-03-31, 17:20:
cyclone3d wrote on 2023-03-31, 17:13:
I'll have to dig it out and build a system to put it in. I'll try to check this weekend and report back.
Thank you, that would be great. I checked my PCI one on a Pentium Pro 233 system running Windows XP, but as I recall ISA GPUs are not supported on XP. As I have NT 4.00 SP6a ideally use NT 4.00 as 9X drivers are often different.
Getting ready to test this, but I decided to look at the NT 4.0 drivers first. Here are the officially supported modes per the ReadMe file:
1.1     Supported Resolutions.
256 colors 65535 colors 16.7 million TRUE color
Resolutions 8 bpp 16 bpp 24 bpp 32 bpp *
640 x 480 2/4MB 2/4MB 2/4MB 2/4MB
800 x 600 2/4MB 2/4MB 2/4MB 2/4MB
1024 x 768 2/4MB 2/4MB 4MB 4MB
1152 x 864 2/4MB 2/4MB 4MB 4MB
1280 x 1024 2/4MB 4MB 4MB N/A
1600 x 1200 2/4MB 4MB N/A N/A
2/4MB - Supported on 2 or 4 Megabyte mach64 products
4MB - ONLY supported on 4 Megabyte mach64 products
N/A - Not Supported
* Note: TRUE color provides 16.7 million colors using a 32 bpp data
format. TRUE color provides higher performance, but uses more
graphics memory.
TRUE color is ONLY available for mach64.
TRUE color at 800x600 is not available on all 2MB cards.
** Note: 24 bpp is available ONLY with the linear aperture.
** Note: Not all color depths are supported at all refresh rates.
** Note: 1600x1200 is not available on all DAC types.
** Note: Only 640x480 8 bpp, 1024x768 8 bpp, and (if configured using
INSTALL.EXE under DOS) 800x600 8 bpp are supported by the mach8.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 79 of 79, by red-ray
cyclone3d wrote on 2023-04-02, 21:28:
Thank you for checking and 1600 x 1200 x 16-bit colour would make me a very happy bunny 😀
I was looking at was was possible on my 4MB PCI 86C968-P (Diamond Stealth64) earlier today which offers almost the same, but noted such as 1280 x 1024 x 16-bit @ 60 Hz did not display well on my Dell 2007FP, but @ 75 Hz did so it would be good to know what rates are supported. I am biased, but feel SIV displays this information well.
file.php?id=161403
